Heros:
Noble: Great weapon, Bow of Loren = 114pts
Spellsinger: lvl 2 = 125pts
Core:
Glade guardx12: muscian, lords bowmen =180
Glade Ridersx8: muscian, standard bearer, Horsemaster = 228
Dryads x10 = 120
Special:
Wardancers x9 : musician, bladesinger = 183
tree kin x3: elder =215
total= 1249
Just starting WE, and warhammer, just hoping for some helpful advice/tactics. thanks in advance.
The Prince.
Heros:
The bow of Loren isn't that great without the arcane bodkins, which you can't get at this level. I would replace it with either the Hail of Doom Arrow, or the amber pendant. Also get some light armour and shield.
Spellsinger: lvl 2
The level upgrade isn't worth it. Just stick to a level one scroll caddy.
Core:
I would drop the unit size to 10, drop the lords bowmen, and only keep the musicians if you have the spare points.
Too big also. Units of 5 with musician is all you need.
Dryads x10 = 120
I would drop these guys to 8 as well.
Special:
Don't mind this unit. You are at the upper end of the size and could lose one or two if you need the points.
tree kin x3: elderReally too expensive for this point level for what they do. And the elder is never worth the points. They just aren't resilient enough without a strong combat themed army to help them out. I would take wild riders instead.
By cutting down on the unit sizes and things you will have the points for a bunch of other things. Great eagles are always useful, Another unit of dryads would be good also.
Good luck,
SirKently
Double check your point values as you are very much overcharging yourself for things.
I also agree with essentially everything sirkently said.
For wood elves at least champions are pretty bad unless you have a character in the unit that you want to protect from challenges.
Wood elves should also avoid putting standards in units with two exceptions: eternal guard, which are block infantry, and wild riders, which should only take a standard if you are giving them the magical War Banner.
Optimal unit sizes are as follows, including characters that you intend to put in the unit:
Glade Guard: 10
Glade Riders: 5
Dryads: 8
Eternal Guard: Varies.
Wild Riders: 6
Wardancers: 7-8
Treekin: 3-4
Warhawk Riders: 3-4
Waywatchers: Varies.
If you want good advice, I'd suggest reading the wood elf tactica on these forums or heading over to the asrai.org and reading the section called the "LEAF."
