Herald of Khorne: Juggernaught, Death Strike, Unholy Strength
Bloodletters x12, Icon, Instrument
Flamers x4, Bolt
Flamers x4, Bolt
Soul Grinder: Phlegm
DP: Mark of Tzeench, Flight, Iron Hide, Bolt,
Instrument, unholy might, breath of chaos
As far as choice of what comes in first if you get it:
Group A
Herald
bloodletters
Flamers
Soul Grinder
Group B
Herald
Bloodletters
Flamers
DP
Constructive comments apreciated :)
Junior Member
I assume these are for each bloodletter unit. I'd drop one, and replace with the following loadout -
Herald of Tzeentch: Chariot, Master of Sorcery, We are Legion, Bolt
and change the other to -
Herald of Khorne: Juggernaught, Unholy Might, Fury
I put fury on him incase of his unit being attacked by a walker. Deathstrike isn't great for it's point - save up for another bolt somewhere instead.
Drop the unit's down to three units of eight, each with fury.
Flamers x4, Bolt
Flamers x4, Bolt
Drop Bolt, and drop them down to three, so that they can all flame on the turn they drop. And then they'll die. Bolt is really difficult to use on flamers, and usually the points are better invested else where.
Drop the DP, he's sooooo expensive, for either;
CC DP; MoN, Noxious Touch, Cloud of Flies, Flight, Breath
or
With the points left over you need some serious anti-tank. Daemons get anti tank from two spots, MCs with flight, or Heralds of Tzeentch with bolt. I'd go for:
2 x Herald of Tzeentch: Chariot, Master of Sorcery, We are Legion, Bolt
This leaves you between 60pts or 115pts to mess around with. Now you can add a couple of icons to the heralds of tzeentch if you like, or get some (but not enough) hounds to close down units quickly and hold them in place.
I don't see what fury would do for the bloodletters, but otherwise I agree with Mathlete.
==Me== also has a point. To compete against mechanized lists you're going to need either speed or bolts. I'd either add some fiends, heralds of Tzeentch, or Daemon Princes (with either flight or bolt).
On that note, that Daemon Prince is far too expensive. I run princes one of three ways:
Tzeentch w/bolt
Slaanesh w/iron hide, daemonic gaze, and pavane
Nurgle w/flight, breath, nox touch, and cloud of flies
I don't like heralds of Khorne. You're better off just using them as bloodcrushers.
Finally, if you're going to use at least one Soul Grinder, you should probably run 2-3. Otherwise they're a little too easy to pick off.
Good luck!
Junior Member
I put fury on bloodletter units so that they're not completely useless if charged by a walker. I know it's not the best chance, but it's better than no chance at all.
