Lash Prince with wings
10x Plauge Marine with champion PF and 2 meltaguns
Rhino with combi melta
10xKhorne Bezerker with champion PF and 2 meltaguns
Oblitorator
Oblitorator
Oblitorator
1500 on the dot
About as cheesey as it can be, but I'm about to help you make it cheesier. First, Berzerkers can't use meltaguns so there's some extra points, second, if you cut 2 Berzerkers and 4 Plague Marines (2 from each squad) you have enough points for 2 more Oblits making 2 squads of 2 and a squad of 1 (or you could move 2 of the ones you already have together and add a Defiler).
Sounds good.
Slight mistake on my part, The bezerkers dont have meltaguns, Just a copy and pasting error!
So whats the best setup for the defiler do you think?
The two I run kept the Reaper Autocannon and replaced the heavy flamer with an additional CCW, though you could go with replacing both of these weapons with CCWs I don't really think there's an official "correct" way of doing this. I kept the RA just incase the battle cannon gets blown off and/or it was immobilized, that way they can't just ignore it for the rest of the game.
7x Plauge Marine with champion PF and 2 meltaguns
8xKhorne Bezerker with champion PF
Vindicator
2xOblitorator
2xOblitorator
Howzat?
Pretty cheesey! I'm not a fan at all of the Vindicator, I'd replace it with a Defiler in a pinch, but with the way your list is set up it might just work!
