I am playing a game with 3 friends, 2 vs 2. I am playing tau... and my other half of the team is playing space marines. I only know 100% what one of the others is play (necrons) there is a good chance the other is elder.
I made two list (anti necron), but want is best and what else should I edit in my list?
1 list:
HQ:
Shas'o
Cyclic Ion Blaster; Hard-wired Multi-tracker; Plasma Rifle; Shield Generator
Shas'o
Missile Pod; Hard-wired Multi-tracker; Plasma Rifle; Stimulant Injector; Shield Generator
Elite:
3 Stealth Suit
Team Leader with Markerlight;Hard-wired, Drone Controller 2 Marker Drone
2 Crisis Battlesuit
Fusion Blaster; Plasma Rifle; Multi-Tracker
2 Crisis Battlesuit
Missile Pod; Plasma Rifle; Multi-Tracker
Troops:
6 Fire Warrior
9 Kroot, 1 Kroot Shaper, 8 Kroot Hounds
Heavy Support:
2 Broadside Battlesuit; Twinlinked Railgun; Smart Missile System; 4 (2 each) Shield Drone; Drone Controller
3 Sniper Drone team
Hammerhead Gunship
Ion Cannon; Two Burst Cannons; Targeting Array; Multi-Tracker; Target Lock; Disruption Pod; Decoy Launchers; Landing Gear
Total Roster Cost: 1499
2 list:
HQ:
Shas'o
Cyclic Ion Blaster; Hard-wired Blacksun Filter; Hard-wired Multi-tracker; Plasma Rifle; Stimulant Injector;Shield Generator
Shas'o
Fusion Blaster; Hard-wired Multi-tracker; Plasma Rifle; Shield Generator
1 Shas'vre
Fusion Blaster; Hard-wired Multi-tracker; Plasma Rifle; Targeting Array
Elite:
2 Crisis Battlesuit
Burst Cannon; Plasma Rifle; Multi-Tracker
3 Crisis Battlesuit
3 Stealth Suit
Team Leader with Markerlight;Hard-wired Drone Controller and 2 Marker Drone
Troops:
6 Fire Warrior
6 Fire Warrior
Heavy Support:
3 Broadside Battlesuit
Team Leader; Twinlinked Railgun; Smart Missile System;Multi-Tracker; Hard-wired Drone Controller; 2 Shield Drone
Hammerhead Gunship
1 Sniper Drone team
Total Roster Cost: 1459
I forgot the necron to tell the necron player playing style:
well not much to say 1-2 lords with orb, mass warrior with some immortals, flayed ones, maybe some destroyers and 2 monolith!!?
Thx for any help
Hi mate, first of all look at the thread i put in and particulalry post 5 or 6 which explains in detail the 2500pt battle i had with a Necron army and how the units faired.
.Shas'O in my opinion is not worth the points, stick with the Shas'El, its cheaper and as effective.
.Deathrains for crisis suits is the way to go very effective, max them out.
.Gun Drones are your friend they have speed they provide LOS protection, they act as speed bumps, they kill and are cheap and as Rikimaru has pointed out to me and i have used, link a squadron with the Shas'El and you have a preverbial circular saw running towards your enemy.
.Personally i would keep the stealth suits simple 6 of them are enough without drones.
.A sole hammerhead i found to be ineffective, you either need two or replace
. Sniper drones (full squad) is needed these babies can pin and take out key units a la Lord, Ctan, Flying Tyrant, Fexes.
This is my 2-cents, good luck
Well my list ended with this and we played necrons and elder:
HQ:
Shas'o
Cyclic Ion Blaster; Hard-wired Multi-tracker; Airbursting frag. Projetor; Shield Generator
Did ok dmg on elder but didn't do much to necrons
Shas'o
Missile Pod; Hard-wired Multi-tracker; Plasma Rifle; Shield Generator
I had really bad luck didn't do as much dmg with this guy because for 1'ens!?
Elite:
3 Crisis Battlesuit
Worked well
3 Crisis Battlesuit
Worked well
Troops:
6 Fire Warrior
well...
10 Kroot, 4 Kroot Hounds
worked as a great meat shield for a good 3 turns
Heavy Support:
2 Broadside Battlesuit; teamleader with Drone Controller; Multi-Tracker; Twinlinked Railgun; Smart Missile System;2 Shield Drone;
as I said was bit unlucky, but did kill 2 elder tanks and hurt a monolith (space marines killed it9
2 Broadside Battlesuit; teamleader with Drone Controller: Multi-Tracker Twinlinked Railgun; Smart Missile System;2 Shield Drone;
3 Sniper Drone team
did kill as much as I thougt they would be and pinning necron is hard!? But still took models out + 2 elder jetbiker's
We won 8X and really with a alot of point 8Y in diff.
Are you going to make any changes to the list after that battle?
I think I would split the 2 groups of Crisis Battlesuit in to 3 groups of 2 making them more mobile, and change one of the teams in to Plasma Rifle and fusion blaster.
Maybe only take 2 teams of Sniper Drone ( and keeping them close and fireing at same target). Broadside and Multi-Tracker is not as good as I remembert it is rare that they can use the 2ed weapon anyway (and even more rare it can do dmg on the targets!) next time I will go with Drone Controller or the "slow and purposeful".
When you play this list you have to move your Crisis and HQ's in to good cover or out of sight, and using range and/or cover for Broadside is a good ideer.
