1 - 12 of 12 Posts
HQ:
Pask w/Punisher, Heavy Bolter Sponsons, Relic Plating
Leman Russ Punisher w/Heavy Bolter Sponsons
363 pts
Tank Commander w/Vanquisher, Hull Lascannon
Leman Russ Vanquisher w/Hull Lascannon
320 pts
Troops:
10x Vets w/heavy flamer
Chimera
135 pts
Chimera
135 pts
Fast Attack:
Vendetta
170 pts
Hellhound
125 pts
Heavy support:
Executioner w/sponson plasma cannons
185 pts
185 pts
2x wyverns
130 pts
Totals to: 1748 pts
Discussion Starter · #2 ·
Here's the revised list
HQ:
Punisher w/heavy bolter Sponsons
393 pts
Tank Commander w/Vanquisher, Hull Lascannon, multi melta Sponsons, relic plating
343 pts
Troops:
10x Vets w/heavy flamer, plasma gun
Chimera
150 pts
Chimera
150 pts
Fast Attack:
Vendetta
170 pts
Hellhound w/multi melta
135 pts
Heavy support:
Demolisher
170 pts
Demolisher
170 pts
wyvern
65 pts
Premium Member
Are you going for an Armored Company theme? My heavy armor Guard usually brings at least one platoon of meat shields so the squadrons don't get one-shotted by a charge. You know the enemy isn't going to sit in his deployment zone and take the punishment.
With so few troops, it's worth asking if you want to do an Unbound list. If it's to run Armored Company then your opponent will probably accept your doing it. That's two LRBTs or Hellhounds you can add.
If only Armored Fist Squads were more reasonably priced...
I would say that heavy armour benefits hugely from infantry support - 'manpower based ablative plating', if you will. Under 300 points buys you two basic platoons (much less if you give them no kit at all, but a vox and an autocannon gives them an inexpensive long-range punch) and a little extra would allow you to put a special weapon squad in your vendetta to go and claim objectives. I would drop an armoured fist squad and the hellhound to make the points available.
About the armoured fist squads - might you be able to make savings if you put the heavy flamers on the chimera instead? They can swap out one or both of their guns for heavy flamers for free, and they usually have to snap-shot one of their guns anyway, so you don't lose much firepower. Likewise, if you go unbound and don't really need the veterans' shooting power, you could take a two-squad infantry platoon, give each infantry squad a chimera and put the platoon command squad in the vendetta. These three squads are only ten points (base price) more than two veteran squads, and this gives you an extra unit in the vendetta for a late-game objective grab.
What is your plan for the vanquisher with multi-melta sponsons? The vanquisher is meant to engage at long range, and the multi-meltas are a short-range weapon, so whilst they aren't a bad upgrade (they are a very decent price) you should be certain that they will be useful. If your opponent favours landraider charges, dreadnoughts in drop pods or overly-friendly forgefiends then they will come in handy, but if you are up against lascannon predators or tau hammerheads then the multi-meltas probably won't come into play. Indeed, Pask is quite a good tank hunter in a punisher with multi-meltas, believe it or not (he can glance landraiders to death with his rending punisher cannon - I've checked the stats) and he might make better use of the multi-meltas.
OK I've taken your suggestions into consideration and swapped out the vets for a basic infantry platoon in chimeras. i also gave the meltas to pask and gave him an executioner buddy. with leftover points i added 2 primaris psykers to trail behind the Leman Russes giving TL and whatnot. it totals out to 1751.
HQ:
Pask w/Punisher, multi melta Sponsons, Relic Plating
Executioner w/plasma cannon Sponsons
418 pts
Tank Commander w/Vanquisher, Hull Lascannon, relic plating
323 pts
2 primaris psykers
100 pts
Troops:
Infantry platoon 270 pts
PCS
Infantry squad w/grenade launcher
Chimera w/heavy flamer
Chimera
Fast Attack:
Vendetta
170 pts
Heavy support:
Demolisher
170 pts
Demolisher
170 pts
2 wyverns
130 pts
Drill Sergeant
You only have one troop choice in that list mate.
Platoons are great but you don't have the points for one and a second troops choice in this list without making some serious sacrifices. I'd stick with the Veterans simply as it fills your 2 minimum Troop slots. Anyway, have you considered using Taurox? It will save you a few points to equip your units.
Two Veteran squads in Taruox both with 2 Plasma Guns comes to 260pts. Give them both H-Stubbers for the last 10points and your gold.
The Taurox models are are so profoundly fugly. I'll opt for a Chimera every time.
I agree. I'm a bigger fan of the military look of the chimeras. Also have that extra front AV and I already have 1 model so... With that said. I revised the troops section to include:
10 vets w/plasma gun
Chimera
Comes out to 10 points extra than the infantry platoon.
Drill Sergeant
Yes, well, you don't use the GW model obviously :p I didn't! Although, the Taurox does look hugely better with wheels instead of those silly track units.
Just a thought, you may want to drop a Demolisher in exchange for a tech priest with servitors. Combined with the lower likelihood of tanks getting popped, they've been working wonders in my lists (and really irritating my opponents).
1 - 12 of 12 Posts
