1 - 11 of 11 Posts
ok i have had two questions pop up this week oddly while playtesting against some new skaven lists with my new daemon lists...
#1
Miasma of Pestilence...
Here's the situation... I have miasma of pestilence(all models in base with the herald are reduced to Ws1/S1/T1/I1/A1) active on my herald of nurgle which is in combat with a unit of plague monks. I use gleen magic on my lord of change and take the spell from the skaven lore that gives a unit -1 toughness for the rest of the game, and successfully blast it onto the unit in combat with the heralds unit. thus i hve two questions alone from this instance...
Do the Monks in base with my herald automatically die from losing the additional toughness from the spell? and if so, when models from the rest of the unit fill in the empty spots do they also die? and i guess if that does happen, would this continue until only the models in the front rank ( basically a 7-10 split) remain or do they have to refill also to proper positioning?
that one was kinda lengthy... and complicated i think...
#2
Are special characters allowed in the Grand Tournament? cause i just finished painting a badass Skulltaker model and i'd hate for him not to see play should i make it to such a esteemed arena.
1) The models in base contact with your herald would go to 0 toughness and be removed as casualties. Models from the back ranks move foward to take the place of the fallen comrades. The skaven wither spell affects them before they are in base contact with your herald, so when they move up they are simply reduced to 1 toughness. In summay, only the models in base contact with the herald when the Wither spell was cast will die.
2) I found the rules for the 2008 tourny, unless it has changed, you should be fine. "Special Characters are permitted, subject to the normal restrictions for that character in the Army Book."
2008 Grand Tournament Info: Page 4 | 2008 Grand Tournament Coverage | Community and Events | Community And Events | Games Workshop
thank you very much for that, me and my skaven buddy could not decide what was the answer to this stigmata. Glad I was right... i didn't want him not to pull that spell against me anymore with his new skaven lol...
but since there is actually someone up this early could you possibly answer one more thing i forget to ask that i meant too?
if slime trail is activated by me being flanked by say a unit strength 5 monster, i know it means they dont get the +1/+2 but does that also mean they don't negate my rank bonus? I figured that was part of the flank charge bonus but I was told I was wrong.
I'm not sure what this slime trail thing is, what unit/where does it come from?
But I do know that the +1/+2 for flank and rear charge is a seperate thing and is listed under a different heading from the negating rank bonus because of being flanked/rear charged. If the slime trail rule just says it makes them not gain +1/+2 for flank/rear then they probably still negate rank bonuses, but if it says something like they don't count as flanking/rearcharging or they lose the benifits of flanking/rear charging, then they probably don't negate the rank bonuses.
If you let me know the wording of the slime trail rule or which book/where I can find it then I should be able to give a clear answer.
Miasma is the level 1 daemon nurgle spell, cast on a 3+ all models in base contact with the herald who cast it are at WS,S,T,I,A of 1 until the start of the herald's next magic phase.
Good old daemon magic
The skaven spell is any unit within 12", they reduce their toughness by -1 for the rest of the game. 8+ to cast
yeh pedro was right on the wording, so that answers my question ^.^ ty very much all.
and yes miasma is nasty when combined with the Noxious Vapors making everything swing last when hes on a palanquin... anyways...
I'm not well versed in Fantasy yet, but reading the effect of the spells, I don't think the monks would die.
The spell states that models in contact have their values set at 1 until the next herald's magic phase. Seeing as this is a magical effect, I don't think it can be altered. Regardless of what other spells are cast on the unit, the miasma states they are at T 1 still.
Does that make sense?
If they were to be T 1 - 1, well, thats not T 1 which is defying the effect of the miasma.
Feel free to disagree, but that would be my position!
1 - 11 of 11 Posts
