First off: Hello everybody, it's been a while since I've browsed around here.
Anyways...
Question 1: A unit of warriors is on the deployment line, 24 inches from an opponent. My opponent goes first and kills 5 of the warriors that I take out of the back. On my turn, 3 come back. The Necron book only states that the models stand back up in coherency. Should "stand up" be taken literally as to they get up where they died unless that would put them out of coherency then you would move them closer.
Or, can I take that as I can put them anywhere as long as they are in coherency, meaning the 3 warriors that stood up would be able to single fire their weapons 24" if I put them in the front of the unit.
Question 2: My opponent kills an entire unit of Immortals. On my turn, there aren't any Immortals within 6" to take WBB. Do the models stay there until another unit comes within range? Or will the models be removed when there aren't any eligible units within 6".
My thoughts are that the WBB roll is optional, so if you don't take it, there is no way for the models to be removed. It only says that the models are removed when you roll a 1-3. If you never roll, you can't remove them.
Anyways...
