See but don´t be seen & Trust your battlebrothers/Eye to Eye
Chaplain – 150 pts
Cruzius Arcanun, Rosarius, Thunder Hammer, Terminatur honours, Teleport Homer
Elites
Dreadnought I – 118 pts
Assultcannon, heavy flamer, smoke launcher
Terminator Squad I - 255
5 terminators, 2 assult cannons, furious assult
Tactical Squad I – 220 pts
Seargent, 9 Tactcal marines, Plasmagun, Vet Sarg, Power Fist, Bolt Pistol, Trust Your Battle Brothers
Rhino, Smoke – 53 pts
Tactcal Squad II – 215 pts
Seargent, 9 tactical marines, plasmagun, Plasma Cannon, Trust Your Battle Brothers
Tactical Squad III – 100 pts
Seargent, 5 tactical marines, missile launsher,
Razorback, Lasscannons - 90
Fast Attack
Assult Squad – 190 pts
Veteran seargent, powerfist, 9 assultmarines, no jump packs, plasmapistol x2,
Land Rider Cruisader – 265 pts
Predator Anhilarot – 145 pts
Lasscannon sponsons
Devestatorsquad II – 198 pts
Seargent, 6 marines, 2 Lasscannons, 1 missile launcher, infiltrate
1999
Hrimfar
Chaplain – 150 pts
this one will join assult squad in the land rider
Elites
Backup for the tactical squads, will else be marching foreward into firing positions
Deep strike if mission permits, will hopefully give the assult squad some extra firesuport when they break the enemies line, exchange the furious charge with tank hunters - will come more in handy!
Rhino, smoke, Hunter Killer Missile – 68 pts
mechanized tac-squad. Good for capturing objects
Stationary squad. Hunting enemiy infantry, can also take out some large targets, maybe even enemy light armour if you are desperate
Razorback, skomelaunshers, Lasscannons - 93
Tankhunter squad, start in cover, then move up deploy tac's and shoot
Fast Attack
Veteran seargent, powerfist, 9 assultmarines, - jump packs, plasmapistol x2
Assultsquad joined by chappy in LR, this is you'r foreward punch...charge if you are able to
Good for breaking down enemy infantry lines before assulting with the marines in it
Predator Anhilarot – 128 pts
Lasscannon sponsons, Smoke Launshers
Devestators that deploy last if the mission is infiltratable. can get really nice shot's at enemy side armour watch out for enemy infantry as it will definatevly chew them down quite fast
2000
That's about it
Fine
Chaplain – 150 pts
THunder Hammer is interesting, I'm one of the few who actually uses a power fist on an IC but thunder hammer is even better.
Elites
ohkay
Good!
I would drop the rhino for a drop pod
If this is intended to join your HQ and assault form the LRC drop the plasma cannon you will never shoot it.
this is ok but you wont ever move this squad, also the razorback cost asmuch as another tac squad with a las cannon. Not bad but if it keeps geting destroyed keep that in mind
Fast Attack
Veteran seargent, powerfist, 9 assultmarines, - jump packs, plasmapistol x2,
Your points are way off, I field this exact squad and it costs 260PTS
good
your points are of again should cost 148 pts
ok
2000
l
Ghost of LO
All your tanks need extra armour. Put the jump packs back on, and give one to your chappy, then ditch the curasider. Give the termintors a drop pod.
Fix your troops
Select from these troop squads, as they are the best:
1 sgt powerfist bolt pistol, melta gun, 8 bolters.
Needs either a drop pod or infiltarte
1 lascannon 1 plasma gun, 4 bolters
1 lascannon 4 bolters
1 plasma cannon 1 plasma gun, 4 bolters
Good luck, minor varations to the above squads wont matter much, this is the way they are min maxed.
Assault cannon dread nought need drop pod.
Devs should be more like, 4 ML 4 bolters.
Remove thunder hammer from HQ, give him a bolt pistol and frags.
Peace
