Hello all, thanks for looking at my post. Any advice would be great. This is for a large tournament in about a month that should be a good mix of players/armies.
HQ:
330
Farseer - Jetbike, Spear, Fortune, Mind War
3x Warlocks - Jetbikes, Spears, 2x Destructor, 1x Enhance
91
Farseer - WB, pistol, Fortune, Mind War
Troops:
220
10x Warp Spiders
207
10x Striking Scorpions w/ Exarch, Stealth, Claw
354
10x Fire Dragon w/ Exarch, Firepike
Wave Serpent w/ Starcannons, Shuriken Cannon
185
5x Dark Reapers
101
5x Howling Banshees w/ Exarch, Executioner
Elites:
65 each
2x Vypers w/ Starcannons (separate squads)
Heavy:
210 each
3x Falcons w/ Starcannons, Shuriken cannons, Spirit Stone and Holofield
Total: 2248
Ok, now for a little bit of tactics to explain the choices! The Dragons and Farseer squad on the jetbikes and 3 Pulse Lasers should be enough AT ?? I hope. Reapers and Spiders help clean up swarm type armies. The 2nd Farseer is flexible, vs. Maries and Necron he will help keep the Reapers alive, otherwise he will go with the small Banshee squad in a Falcon to crash into lightly armored troops. The goal here was to keep a fairly mobile army that can still have decent CC and AT capabilities.
Thanks in advance for your comments!
señor brushman!
330
91
Maybe take out Enhance and add in another Destructor but its up to you. Be sure to use hit and run with that unit and remember, when turbo-boosting 24" your save becomes inv.
If your second Farseer will be with the Dark Reapers, take out Mind War because it will probally never be in range to use it sense the Reapers will be sitting 36-48 in. back shooting.
354
10 Fire Dragons is usually a bit over kill - especially against vehicles. Take out 4 dragons, put em' in one of the Falcons, and give the Wave Serpant to the Banshee's. Be sure to beaf up those banshee's with the pts you took away from the Dragons.
Good luck in the tourny!
~Ben
The Love Muffin
-Drop Mind War on both Farseers. You will use Fortune a lot more, you might use Mind War, but it won't be worth missing that ward save reroll.
-Try dropping a few Warp Sipers. To be used properly they a lot of room.
-10x Fire Dragons is overkill. Drop the unit to 6 and load them in a Falcon. Then give the Wave Serpent to the Banshees.
Other than that, this list looks really effective.
