1 - 20 of 55 Posts
Here's my 2nd attempt at mech guard, hopefully it's a lot more effective than my 1st attempt as it's got a lot more units in it.
110 – Command Squad:
4 Plasmaguns
55 – Chimera: Multi-Laser, Heavy Flamer.
(I originally had 4 Meltas, however Plasmaguns can benefit better from the orders that make them twin-linked and demand re-roll successful cover saves.)
TROOPS
100 - Veteran Squad: 3 Meltaguns.
(Your standard mech squad tactics)
FAST ATTACK
130 - Banewolf:
Heavy Flamer.
130 - Banewolf: Heavy Flamer.
(These guys ride up behind the chimeras and move up to deal with the more threatening squads ie anti-tank equipped)
HEAVY SUPPORT
190 - Leman Russ Battle Tank:
Heavy Bolter, Plasma Cannon Sponsons
(I’ve made this my most threatening unit to force enemy fire away from the rest of my army, of which it can take a beating)
160 - Manticore: Heavy Flamer
(the perfect anti-horde killing unit)
75 - Griffon Mortar
(Best thing to get for the pts I had left, since I’ve already got all the anti- armour/meq I need)
Total Pts: 1470
Total No: 45 ( 10 )
Kill Pts: 15
An aggressive list, but the big thing that has me worried is the lack of ranged anti-tank that why I’m considering replacing one of the banewolves with a Devildog, what do you guys think? Please I’ll say this now no Valkyries and Vendettas they just would fit in with the army’s low tech appearance!
I’ve also got 30pts left to spend, here are a few options to buy…
  • 3 Hunter Seeker Missile for the chimeras some ranged anti-tank.
  • Camo Netting for the Manticore as it is a threatening unit.
  • Multi-Meltas for the Banewolves to give the army some effective ranged AT weapons.
  • Extra Armour For Command Squad’s Chimera & 1 Multi-melta for a Banewolf that squad’s transport needs to keep moving.
FOR 1750PT GAMES…
For the additional 250pts for games of 1750pts I have two options…
100 - Veteran Squad: 3 Plasmaguns.
80 – 2 Scout Sentinels: Autocannons.
(1 Chimera for sitting on objectives with some outflanking Scout sentinels for tank hunting.)
- or -
Infantry Platoon
40 -Infantry Command:
Autocannon
70 -Infantry Squad: Missile Launcher and Grenade Launcher.
(A Good big unit to hold down objectives on my side of the board while providing some long range support, I prefer ML due to their flexibility)
What do you think? I really need to get to start work on this army asap!
i would switch the banewolfs to vendettas, because 5 chimeras are enough anti-tank. plus the manticore is too fragile and the leman russ si too expensive. swap them for demolishers and they will provide better anti-termintor/nobz and anything else like anti-tank and horde should you need to ^^. it makes your army much harder to kill and they have rear armour 11 so even marines without a powefist can't do a thing. also griffon for marbo? and switching one of those plasma guys for a regimental standard.
thanks
antique_nova
Formerly Prince of Excess
I'd drop the sponsons off the LRBT, they're pretty useless and expensive. Give it a hull HF, even though it has a long range main gun you'll still be advancing.
Give the Griffon a hull HF for DS and Outflanking troubles.
That gives you 70 points because apparently you're 30 short. I'd roll with Sentinels, you're weak on long ranged anti-armor and Sentinels are great at charging hold back gun units like Battle Suits or Dev Squads.
Really how can you say that 2 plasma cannon shots for 20pts each is a waste? combined with the battle cannon I can pretty much wipe out most MEQ targets I fire at?
The griffon does have a heavy flamer, just forgot to mention it.
Because I never advocate any Russes besides a generic or a Demolisher and I never advocate sponsons. They simply aren't needed. You're making an expensive tank more expensive and hindering it's ability to advance.
A well played Mech army leaves little to nothing in the backfield, especially nothing with AV14. You need that Russ to block sides on your Chimeras and add to an imposing rush. If it's doing those important jobs, the sponsons won't be firing. You're paying 40 points for 2 backup guns to the turret basically.
I always keep my armor up front and moving unless there is an OVERWHELMING (caps for emphasis) Melta threat which isn't typical. If it loses the turret, I use it the same way Ork players use Battlewagons, Tank Shocks, armor protection and in our case, Hull HF.
Explanation = explained.
just to echo prince of excesses advice and that you should listen to him ^^, he is the msot experience 40k member that i have met ^^. hopefully the guy who's better is me :D.
thanks
antique_nova
Because the Russ will have to stay still to fire them. Moving tanks can:
1) Adapt to the field and get cover when they need them.
2) Deny cover to their targets.
3) Provide cover to infantry and other tanks.
4) Tank shock units.
5) Make it a LOT more difficult for assaulters to kill them.
Nobody ever believes me until they see it, but my Russes live (on average) twice as long as they used to when I put sponsons on them. That means the Battle Cannon is firing 2-3 turns more, and those shots are in the late game, when the target environment it richest. So the net gain is 10+ more dead MEQs than I had before.
Your list is pretty strong. Here's my suggestions:
1) Put a lascannon on the Russ so it'll have a better chance of taking out transports on turns one and two. You'll also want a second Russ, or preferably a Demolisher with a hull HFlamer.
2) Swap the Banewolves for Hellhounds. The extra 12" range of the Inferno Cannon makes all the difference. You can also put hull multi-meltas on them for shooting at transports on turns 1 and 2.
3) Get a squad of 3 scout sentinels with autocannons in there for (again) popping transports on turn 1. They're also great at tarpitting enemy squads.
4) Put your plasmas in a Vet Squad. Plasmas are great at defending an objective or the backfield in general. But you want that unit to be scoring as well, or you'll have to leave 2 tanks behind instead of one.
Here is what I hope is my final list, I've changed one of the Banewolves to a Hellhound for the extra range and horde killing factor, I've also swapped the command squad's plasmaguns with 2 of the vets squads. Cause if one of those overheat at least I've still got another 9 guardsmen to shoot with, plus they can still do damage when parked on an objective...
90 – Command Squad: 4 Meltaguns.
55 – Chimera: Heavy Flamer.
TROOPS
100 – Veteran Squad: 3 Meltaguns
115 – Veteran Squad: 3 Plasmaguns
FAST ATTACK
130 – Hellhound: Heavy Bolter.
145 – Banewolf: Multi-Melta.
HEAVY SUPPORT
190 – Leman Russ Battle Tank: 2 Plasma Cannon Sponsons
160 – Manticore: Heavy Flamer
75 – Griffon Mortar: Heavy Flamer
TOTAL PTS: 1495
TOTAL NO: 45 ( 10 )
KILL PTS: 15
FOR GAMES OF 1750PTS
10 –Upgrade Leman Russ to Eradicator
-- OR --
250 - Leman Russ Punisher: Heavy Bolters & Pask
(Excellent against nids and orks which is good since my army theme is ork hunters)
(these will replace the griffon mortar to free up space for the Punisher.)
What do you think? Also which 250pt reinforcement should I go with?
Also I'm experimenting with a Valkyrie conversion, if it works the command squad will be mounted in it and I'll remove the Griffon and upgrade the Leman Russ to an Eradicator.
Firsty, I agree with the previous posters that the Plasma Sponsons really aren't required, if possible you could change the LRBT to a Demolisher (also previously mentioned). But you seem to WANT the plasma sponsons, so I won't argue. They are a lot of fun if you get the time to use them :p
Secondly, I do think you were better off with the Plasmas on the CCS. The power of laying down 8 Twin-Linked plasma shots on a MC is all to good to pass up. And, I know, you'll still be abe to do that by ordering the other unit, but that means that they are forced to work in conjunction with eachother.
I also agree on exchanging the Griffon for Marbo. The Griffon is a nice piece of machinery, but as far as i've figured they're best used in pairs.
So if you've exchanged the Griffon for Marbo and switched the plasmas back to the CCS, you'd have 10pts left over to spend on whatever you'd like ^^
And for the larger games, I would actually advice on using the Infantry Platoon you posted first. It's always nice to have a firebase able to hold a home objective.
Otherwise I find it quite nice, altough I've always had a problem with the Chimelta-Vets spam ^^'
Anyways, I wish you good luck with this army ^^
Cheers ^^
Discussion Starter · #10 ·
But surely the Plasma guns are better for holding objectives and the vets can take losing a man, where is the command squad suffers a lot.
A friend has recommended I replace the Leman Russ and Hellhound with a Leman Russ Punisher with Pask & HB + replace the Griffon with a Standard Leman Russ or even a2nd Griffon?
He says since the rest of my army is mostly anti MEQ & armor it would give me a good weapon against hordes and monsterous creatures.
demolishers work better and they cost a damn sight less. punishers? if they are the one with 20 shots. that's a waste of a tank with BS4. might as well get griffons if you want anti-horde or chiemras with heavy flamers. if it's the S10 one shot russ then, i wouldn't rely on it/ it's one shot and melta guns and lascannons are cheaper and have a better chance to break tanks that a russ which is a very big fire magnet.
thanks
antique_nova
Discussion Starter · #12 ·
Well here is final list. I've gone with the Valkyrie for the seer horde killing power it provides, I've got enough melta weapons in this army to deal with vehciles and big creatures. As for the comments about the Leman Russ I want to keep it as it is a threating target for my opponent drawing fire away from most of my army as it advances laying down a barrage from all its weapons due to the 'lumbering' rule.
90 – Command Squad:
4 Meltaguns
TROOPS
115 - Veteran Squad: 3 Plasmaguns.
(mounted in Valkyrie)
FAST ATTACK
140 - Valkyrie:
Rocket Pods and Heavy Bolters
130 - Hellwound: Heavy Flamer.
145 - Banewolf: Multi-Melta.
HEAVY SUPPORT
Total Pts: 1500
Total No: 45 ( 10 )
Kill Pts: 15
FOR 1750PT GAMES…
Total Pts: 1750
Total No: 55 ( 13 )
Kill Pts: 18
good luck using the demolisher with plasma cannon side-sponsons. its make an utterly brilliant unit if you use it right. i think the main opposition to it is that not as many people use them. 20 pts. is acceptable but dont be afraid of moving your russ forwards because you wont get to fire the plasma cannons. they are best used in defensive missions - utterly brilliant as support for an objective holding unit
not bad, but i really don't like your heavy support options at all.
I second that. Guard is all about quantity/reduncancy. Two Russes would force your opponent to make more decisions on what he uses his AT on. One Russ with sponsons is less effective than two. What happens if it gets destroyed? Plus, those plasma cannons could easilly scatter.
Doh! Missed that!
Yeah, take the sponsons off the Demolisher and take a heavy flamer on the hull.
Discussion Starter · #19 ·
Okay I'm curious to know why does everyone hate Plasma Cannon Sponsons, so can you answer these questions?
  1. What do people think I can move the russ forward and fire the plasma sponsons, the 'lumbering' rule allows all weapons to be fired at combat speed?
  2. If I get rid of the plasma cannons sponsons where should I spend the 40pts?
  3. WHY A HEAVY FLAMER ON THE RUSS? They're not fast enough to be threating with them as they can only move 6+D6 at top speed due the lumbering rule?
Drill Sergeant
1: Sorry dude. the lumbering rule lets you fire the turret weapon "in addition to weapons you may normaly fire". So if you move at combat speed you're normaly only allowed to fire 1 weapon but the lumbering weapon lets you fire the turret weapon as a bonus!
2: You don't need to. In a sit back and shoot list a Plasma Russ is fine. If you're going for a mroe aggressive mech army i'd just go for a Demolisher as it has better rear armour and the shorter range doesn't mean anything as it will be moving forward and supporting your Chimeras.
3: It's personal preference. Some people like H-Bolters as they can fire lots of times and think that if the enemy are in Flamer range anyway, you'll be dead Flamer or not. On the flip side some people think that a single BS3 Bolter will do Jack so would rather have that 1 good Flamer shot to try and save their Russ.
1 - 20 of 55 Posts
