Noble-141
lance
heavvy armour
barded elven steed
shield
Temakor's gauntlets
Dragon mage-435
lvl 2
the gem of sunfire
guardian phoenix
16 archers-201
full command
14-archers-179
full command
2 Tiranoc chariots-170
2 Lion chariots-280
5 Dragon princes-200
Full command
RBT-100
Total=1506
or
Noble-141
lance
heavy armour
shield
barded elven steed
temakador's gauntlets
Mage-160
lvl 2
silver wand
jewel of the dusk
15 archers-190
full command
14 archers-179
full command
15 spearmen-160
full command
2 Lion chariots-280
full command
10 White lions-180
full command
RBT-100
Total=1495
Which do u think would be most effective or how could i change them? Need feedback8Y
Personally i would prefere the second list but then i don't like dragon mages. It depends on what you intend to do. I would ceratinly loose the commands on both of the archer units and take them both down to 10 men. I would replace at least one unit of charriots with a second unit of DP's, I would also loose the full command from the DP's just keeping the musicians if you are going to use two DP units, the DP's IMHO work better in pairs one hitting from the front one from the flanks. If however you intend to keep only one units of DP's take them up to 6 with a full command and warbanner. Charriots generally are not very resilient even against basic bowfire, and therefore i would replace both units and bulk up your DP's, spearmen and elite infantry. However this is only an oppinion and you have to game with an army you are happy with, good luck and have fun!
Herman1004
Hi
First list:
*IMO you need magic defence. As your only caster, I think the dragon mage should have a dispel scroll instead of the gem.
*Thats very many, weird numbered archers. I think 30 archers is way too much. I rarely field more than 10 of them. If you really want that many archers you should split them in three groups of 10 with no command except maybe musician as a points filler.
*SO...MANY...CHARIOTS... Against a shooty army these won't stand a chance. Drop the Tiranocs for a unit of 12 elite infantry (your choice)
Rest is fine.
Much of the same goes for the second list as well. Archers, chariots and your mage. Your mage has got two arcane items. Drop wand and give him a dispel scroll. It pleases me to see that you have brought in some spearmen in here as well.
Hope it helped.
