Hello all-
I'm going to be playing a bigger game against a DA player at our store. I wanted to make a list that was different from what I normally field. I've played this guy before in smaller pt games and standing and shooting doesn't work so well. Anyways, tell me what you all think.
HQ: 405
Lord w/ Dest Body, WS, Res Orb, GoF
Lord w/ VoD, Res Orb, WS
Troops: 810
Warriors x15
Warriors x15
Warriors x15
Fast: 496
Wraiths x3
Wraiths x3
Destroyers x5
Elite: 700
Flayed Ones w/ Dis Fields x10
Immortals x10
Heavy: 580
Monolith x2
Tomb Spiders x2
Total Pts: 2991
Total Models: 88
PO: 22 Models
Anyways the idea is pretty simple. Attach the Dest Lord to the Wraiths and have them run up the flank to start hitting him from the side, hopefully getting to his Dev Sq before they can do any real damage (he is quite fond of those squads). I've had very good luck with them in the past in this role, so hopefully they won't let me down. Depending on the senario and rules being used I will either inflitrate the flayed ones or if it looks safe maybe deep strike them as close as I can. I'm not really worried about taking out his vehicles too much, but more so the troops.
As always, advice is appreciated!
kut maar krachtig
hey mate,
well first of goodluck with the match. second i would drop a monolith and add 3 heavy destroyers to crack some hard armour. I would consider dropping the warsyth on the footlord aswell unless u really expect a lot of cc inv saves. but besides that looks like a solid list I personnaly like the wraith lord setup a lot. but I would consider dropping the gaze of flame and take phase out too stand your ground against powerweapons.
again good luck and let us know how it went.
If u dont care much for enemy vehicles i suggest u to drop the DFs from the Flayed ones. We are talking about 3 pts less for each FO that comes to a total of 60 pts less in ur army list. With these point u can either put another tomb spyder and some warriors or u can just pump up ur current warrior squads.
Well this is what i would have done in your list. The rest of the list is pretty good and hard to bring down.
King of Librarium's Tombs
If you were to loose a HS for some Heavy Destroyers, id say drop the Spyders. The Liths will have far more impact on the game.
Also id say run Warriors in units of 10, and as above, drop the DFs from the FOs.
Its a shame your not playing Apoc really, or even just using 2xFOCs. It does say in the main rulebook you can use 2 once the points get high enough.
