I was reading one of the other posts in this forum (the one about extra attacks) and this popped into my head. What if you used the 40K rules for everything but assault, and switched to D&D combat rules when you got to it? It would make the game much more detailed as well as making the smaller skirmishes (750pts or less) slightly more interesting. Can anybody else see this working or being even vaguely viable?
Oi! :eek:
Zoom in for a D&D battle? That would be TERRIBLY time-consuming and confusing, replacing all the D6 with D20, D8, D12, etc. and transferring inches to feet and.... blargh! *head explodes* Let's just leave WH40k the way it is. :rolleyes:
Or you could use Inquisitor...
Heh, it was just a vague idea that popped into my head. It might work a leetle bit. :p
It could work, but I don't know how many people would dig it, especially when it came down to 20-man teams going at it. *shudders* Oh the agonizing D&D battles....
But if we did stick it in, Khorne's greater daemon is a pit fiend. :p
Yeah, I suppose so.
First thing to go? Armour saves. Just increase toughness to reflect armour. It's much easier that way.
Then what about power weapons? and invulnerable saves? kinda jumble everything up a bit. And toughness repersents their over all abilty to take a blow, while save is their abilty of their armour or something simlar.
Slayer's right, it would kind of screw everything up. If you want to make the close combat system more detailed, why are you taking things out?
YOu need to get rid of the crap to improve it, which is the primary aim. You check to see if you have hurt someone and then roll to see if their armour deflected it? Pointless. Boil the system down to it's basic and then start adding from there. Else you'll get a rickety structure that will be even more convoluted than the current assault rules.
Invulnerable saves then become an extra safety net. Once you have your T beaten, you can then take the Invulnerable save. Power weapons pose slightly more of a problem. One has to consider the introduction of modifiers into the system, which shouldn't be done lightly... I have it! You still have the two values T and Save but you add them together to get what the S needs to beat. It needs refinement, but I believe that might work. Roughly thinking (off the top of my head), Str vs. (T + 1/2(7 - Save)).
You never know, it might work. :D I'll try and refine it some and post that up.
