For the Tau player, insist on only playing nightfighting and then make your army based on the usual boltpistol and closecombat weapon, mount them in Rhinos, and he should have a slight problem...
For the necron player, make sure you have a lot of str. 8 or higher weapons just to make sure that the pesky warriors don't get up again.
Then shoot all the destroyers.
Try luring the warriors into a fire pit... that is get them to a spot where thay can be shot at from all directions...
with the tau dont do the "Ill only play this scenario" thats just bit'chin. It is true that the chapter you are playing will affect the game aswell as the fact that how is the tau player playing tau. Is he using the tau speed or the broadsides. We need to know the sides before we can call the playes.
Lord of the Household
You could use this to your advantage as Tau are exellent at shooting but not so good in CC... If you can lure him into CC or get your troops as close as you can you shoud have no problemo... Maybe you could get hold of a bike squadron or a 10-man assault squad. In my experience Termies are also good against Tau.
As for the Necrons I agree that you need to use a lot of firepower and powerful weapons to keep those suckas down once they're hit...
When I play against Tau I usually stay with heavy firepower in cover, let the obliterators ,or termies for that sake, stomp to the target together with dreadnoughts.
In addition I always have one rhino capable of flanking the tau forces.
Stay out of sight of the battlesuits, if you see any stealth suits, shoot them with all possible weapons, every one of them guys has got a burst cannon, almost like a heavy bolter... and they move with it and fire.
Assault the firewarriors, they're not much in CC.
And for gods sake take out the pathfinders, you'll find out when they start marking you with markerlights...
