1 - 13 of 13 Posts
Unfortunately for me one of my friends and usual opponents has acquired a Nightbringer for his ever-growing Necron army, which has prompted this post. Put simply, are there any effective ways of dealing with Necrons and the Nightbringer when playing Tau? I've already tried the traditional Tau tactic of throwing everything at them save the kitchen sink :p ...and yet they still come!
...help....
I don't know the Nightbringer that well, and I've only rarely played against Necrons (none of my regular opponents plays them), but here's what I tried (and it seemed to work - but then as I said, I don't know the Nightbringer).
One thing about Necrons is that the common Tau strategy of 'throw a h*ll of a lot of bullets at them and eventually they'll go down' doesn't always work...
Thus, when I wind up playing Necrons, I tend to adopt the 'get a few squads of Fire Warriors to be unfriendly to the Lord carrying the Res Orb and use massed crisis suits and broadsides on the others' tactic.
Yes, the Tau get less shots, yes, its more than a little overkill firing a twinlinked railgun at a Necron Warrior - but at least the irritating things STAY DOWN .
Try to aim your fire to cut units off from the main mass, then pour your Stealth Suits' and Fire Warriors' fire at the isolated units (ideally taking the whole lot down, with them more than 6" inches away from a standing model). If the strategy works, it should result in both flanks of the Necron force being sliced apart... and a large mass of Necrons in the centre nearing your lines, hopefully with a dead Lord.
This is the part where you rapid fire your fire warriors, fire templated Hammerhead shots, and basicly pump pure firepower into their front lines, and do your best to get them past the 75% phase-out point before they hit your lines. If they *do* hit your lines, make sure your fire warriors are in the lead, and scatter your suits... and then open up on them the moment they get free of your warriors.
As a note, sometimes its worth letting a lone survivor of a Warrior Squad catch your Stealth Suits, as with their 2 attacks each and portable-cover effect, they stand a fair chance of killing him and moving on the next turn - particularly if the Necron player hasn't heard about this rule - as mine haven't most of the time B)
For the Greater Good!
How about broadsides with plas. rifles? They'd do some good chopping.
Oh, and you might want to try throwing the kitchen sink just incase.
A little calculation i have done, being an a-level stastics student...
On average, it takes 24 pulse rifle shots to cause 1 wound on a nightbringer.
Take 36 fire warriora and jjust blast it. 3 wounds every 2 turns and it goes down in 2 turns (probably more as you will suffer casualtes, say 3 turns. It's in rapid fire distance on turn 3, so it'll die then). And 36 fire warriors cost 360 points. So does the nightbringer. And after they kill the nightbringer then you can just blast any warrior squads stupid enough to come in like of sight. Oh yeah, kill the tomb spyders and wraiths as quickly as possible with your crisis suits as they can cause lethal damage very quickly. After the ctan is down, the main thrust of the army dies (normally a necron player relies too much on this, espically in 1500 points or less, it's too expensive for armies this big) and if it doesn't then concentrate plasma rifle fire on one squad until it goes down totally, then move on to the next. With the gauss flayer rule i find tanks go down too quickly, so i prefer the broardsides. And the railguns can seriously piss off necron lords who expect to get the "we'll be back" roll from everything.
Oh yeah, necrons aren't too good in close combat (too slow & not enough of them) so the only thing you need to worry about is the wraiths, maybe the flayed ones, but if he has a ctan as well as there elite troops then you should be get him to phase out on turn 2 cause he will only have 20 warriors.
I recomond that you destroy warriors and smaller squads of a single unit type, like 3 destroyers, as to deny wbb rolls, and relentlsly destroy there warriors, as they should have a reasonlble size of warriors to prevent phase out. If the lord uses veil of darkness to land near you, fire everything that turn at him, hopefully elimnating him and what ever he trys to take with him.
Indeed, thanks for the suggestions, and I have managed to gain his full army list plus mine.
NECRONS
Nightbringer
Necron Lord w/ WarScythe, Resurrection Orb and Phylactery
30 Warriors w/ Disruption Fields
5 Scarab Bases w/ Disruption Fields
3 Destroyers
vs, and don't laugh:
TAU
Aun'shi
[Shas'o w/ Fusion Blaster, Plasma Rifle & Missile Pod, + hard wired Multi-Tracker, Drone Controller and Blacksun Filter, and a Shield Drone.
1 Bodyguard w/ Plasma Rifle, Flamer & Multi Tracker, + Hard wired Target Lock, BONDED]
[11 Fire Warriors +Shas'ui w/ Pulse Rifles, Photon Grenades & EMP Grenades. Shas'ui has hard-wired Drone Controller + 2 Gun Drones, BONDED] x2
[4 Stealth Suits + Shas'vre w/ Markerlight & Hard-wired Blacksun Filter, BONDED]
[4 unit Gun Drone Squadron]
[Broadside Shas'vre w/ Smart Missile System, Shield Generator + Hard-wired Blacksun Filter, BONDED]
Ok I don't play Tau myself but I used be sort of an "advisor for a friend of mine...
He got tired of Tau and started the Necrons...
The big str. weapons are essential...
But also think about the Necron phase out rule...
If their total number of models in play goes under a sertain percentage of the starting number the army phases out... and you win...
Other than that I'd say the number of guns brought to bear will have a significant word into the outcome...
You should try to maximize the number of models on the table. Just spam the hell out of them until half are gone.
I'd scrap aun'shi (although he is a pretty sweet model) and throw some more battlesuits in there. I'd say that even with aun'shi, Tau are pretty screwed against the necrons in cc.
25% remaining. So a 1500 pt. force with two Monoliths and a Deceiver, total 770 pts right there, is at a huge diadvantage. Ignore them and you basically have twice the points of his army and you only have to kill 3/4 of it to win. Just avoid the slow-moving C'tan and Monoliths.
I played against Necron last week, 1000 pts cleanse battle, ended in a Tie with not much left on the table.
Pathfinders (with railrifles) did very good with thier good AP and seekers missiles, destroying the enemy wraiths and destroyers in my first 2 turns. Lets just say the other guy was *****ed off.
I dont think firewarriors score even one wound in the game, but again, I had small units.
Hammerhead did relatively well with its long-range Ion cannon. Its range saved it from those nasty gauss weapons.
Crisis suit and Shas'o with plasma rifles got sucked into Hth combat early in the game, the Shas'o and its drones help up the enemy lord and those mean hth dudes for nearly all the game.
I had strong but few fire-power. Early in the game it worked well while I was blowing off its main units, but in the end I simply couldnt fire enough shots to mow down his warriors and force a phase out.
Basically my strategy was picking anything with an AP better or equal than 3. That kinda neutralized its WBB since he wasnt making any armor save from shooting. But he used terrain better than me and that made the tie.
Hopes those tid-bits can help.
i played necrons yesterday and won to my great delight in a 1050pt battle he spent 200pts on a necron lord (including armoury stuff) 300pts on a deciver and 100 pts on a 2 man destroyer squad. thats 600 of 1045 pts plus a heavy destroyer (i can't remember what that came to). we then rolled for table edges and ended up on a hill facing him behind a row of hills. he then made his first mistake by moving his lord and deciver through the hill, apparently they can. and his destryer squad on top of it. he fergot to move his warriors. broadsides take down 2 destroyers. lord picks 1 destroyer up again. hammerhead inflicts 1 wound on deciver, crisis kill 5 warriors 2 stand up again. massed fire warrior shots do nothing. destroyers kill 4 fire warriors. deciver and lord move forward. warriors do drasticaly bad in terrain tests, 3" and 2". broadsides take out destroyer (well both but the heavyn stood back up again (damn lord) ) hammerhead inflicts wound on deciver. crisis kill 3 warriors. heavy destroyer kills one fire warrrior deciver kills one, lord and deciver move forward. lone fire warrior (out of six man squad, past all ldship tsts). inflicts wound on deciver! massed rapid fire from other firewarriors kills deciver but after broadsides drones and hammerhead fire at lord. crisis don't kill any warriors. destroyer fails to kill lone warrior. he remembers to move his warriors another pitifull 4" and 2". lone fire warrior kills heavy destroyer! no one within 6"! rest of fire kills 6 warriors. damn 1 more an he would've phased out. tau win by substantial margin (tau lost 4 bonded fire warriors and gun drone) necrons lost a lot more.
the one lone fire warrior has now got an amazing kill total to his list scince i do what it suggests in the rulebook and keep a list of all that some things have killed this one fire warrior (shas'el 255) has got 2 vypers 24 orcs and grethins, 6 ig men, 2 sm terminators 1 dh termi 2 warriors necrn, deciver, 2 destroyers, orc war boss wow and i've only been playing for 6 months!
this must be my longest post ever.
Did He got a destroyer back up from a destroyed unit?
Correct me if Im wrong, but even with a lord with a Orb of Ressurection near, dont you sill need a model of the same type less than 6" away to use the WBB rule?
1 - 13 of 13 Posts
