Anti-Tank Weapons
1099 Views 23 Replies 13 Participants Last post by  Ryiax
Well so far my Witch Hunters have only won one out of six games:cry: I've noticed that the thing that always turns the battle is tanks. So my question is what is the most effective anti-tank weapon that the sisters possess? I've enjoyed the one retributor squad I have with 4 multi meltas, but that is pretty pricy.
1 - 20 of 24 Posts
give the retributers back there heavy'b's !
2 exorcists is pretty standard even one is enough to down most any tank in the game, domminions would be 2cnd a unit of 6 in a immolater with heavy flamers and the4 sisters have melta guns with a vet with combi-melta , drive it to tank disembark fire the dommy's at tank and then flame the occupants that survive the boom.
Equipping a Battle squad or Celestian squad or two with two meltaguns is a flexible and cheaper alternative to the quad melta Domins.
Seraphim can be deadly AT'ers when fitted out with any of Inferno Pistols, Eviscerators or Melta Bombs. Small squads work best for this as they don't need the numbers for assaults so much. The same goes for Jump Pack equipped Canonesses.
Immolators with MM aren't that effective. They have to get within 12" to be able to reliably penetrate armour, which is difficult for such a lightly armored vehicle.
Above all though the Exorcist is your AT with Sisters. I've seen battles where one has knocked out 3 or 4 enemy tanks. It is particularly deadly against medium armored vehicles because it can easily penetrate their armour (penetrates on the same roll as a Lascannon) but gets multiple hits, so has more opportunity to get a destroyed result when rolling for damage. It also has the ability to move and fire at full effect, so be sure to use this to duck in and out of cover and acquire firing lanes.
Multimeltas used to be deadly way back in 2ed days, but are now useless. They simply lack the range of lascannons, and don't even quite equal them in hitting power really. Getting a heavy weapon within 12" of a tank and then firing it is a tall order, and past 12" they aren't too hot. Meltaguns in practice work better. The old MM never turns up in Space Marine lists, not even Salamanders.
Pretty much as said above, you won;t win many games relying only on a multi-melta unit. I used them when i first got the army and found them to be too short ranged and too slow (even with an immlator to get them places) Retributors are better suited with heavy bolters.
yes, give them their hvy bolters back!. Anyways, these are my AT units in 2000pt games.
1.) My two exorcists
2.) My mounted battle sister squad w/ 2 melta guns + plasma pistol
3.) Seraphim Superior w/ eviscerator (never use the TL inferno pistols)
4.) Canoness w/ inferno pistol
5.) Grey Knight Terminators w/ 2 psycannons. (light AT, decent against standard armour if you can hit back armour.
I stray from dominions as their weapons prices are higher and my mounted squad can do the same thing essentially.
Hmmm I don't really like the eviserator to go against tanks, I think it's a nice backup in case the shooting failed but hitting on 6+ on skimmers and tanks which have moved a fair bit is too much of a long shot. IMO anyways. With shooting weapons your chances to hit arn't reduced so I think it may be a more stable solution when knocking out tanks.
+ shes still only str 5 so ur restricted to light or medium tank hunting
Eh? She's STR6 to begin with, plus you get TWO dice for penetration (in all respects like a chainfist...)
Were you thinking maybe of a Blessed Weapon?
Exorcist has to be our number one AT.
I use two other options in my list as well as an Exorcist.
1./ Canoness with jump-pack, Cloak of St. Aspira and master-crafted eviscerator. S6 + 2d6 dam vs vehicle or Faith(+2 Str) for S8 + 2d6. 4x attks on the charge with a re-roll almost always gets you a hit. +2 save (faith for invulnerable) if she's left hanging in the breeze afterwards. S8 is also great for IC killing.
2./ Sera unit of 5x models with 1x flamer, 1x inferno, 2x BP's, VSS with 2xBP's and melta bomb's. Cheap unit thats very anti-tank and a great objective gatherer.
IMHO meltas in the troops iarn't worth the points. If a tank is 12" away, you're in trouble.;)
Doms, with meltas...they are better off with flamers.
Multi-meltas in any unit are very expensive...I'd only consider them as an Immy upgrade where you get a re-roll to hit or with retribs in a 3x HB, 1xMM config, but this is not my preffered retrib config...you got to love the 4x HB's.:)
My 2 cents.
Cheers
Mark:ninja:
long range AT is really the main weakness of th e SOB. But who care? We are close range fighters.
I use one or two exorcist(s) of course, but do not rely on them. although they are powerfull, with strenght 8 it can be long to shot down tanks with 13+ armor (once, fired 4 turns on a hammerhead without having it, darn antigrav!).
So my main force is AT equiped. Sisters with melta, cannoness with inferno, seraphims with infernos. Since I use my sisters as an motorized assault force, it works: as soon as my sisters are close to tanks, bye bye.
I don't like the eviscerator because my opponents tends to have antigrav and its a pain to catch them in CC. But its a personnal choise.
I liketo take an immolator with meltas sometimes too, rushing with rhinos to close range. Note that it is toasted everytime but it drives away heavy fire from my precious sisters in rhino or my exorcists.
Again hitting is a big problem, cheaper solution is master crafted-inferno pistol.
Each of my standard Troops Battle Squads carries two meltas if I am fighting anything with tanks.
And my Seraphim take Inferno Pistols and melta bombs
-981
i'm not a big fan of the inferno pistols cus they leave ur squad waaayyy to close to the enemy usally unsupported and generally provides a suicide effect all so ya can get a single tank that may or may not blow up so in my book it jus aint worth it. :(
The simple answer has been given to you - the exorcist is THE way to take out tanks at range, for sisters, in a battle of 1000 points+ always, always take 2 (actually if you face an IG foot army you may be better off without them, but otherwise).
Other than that I can not think of a single sisters squad that can not turn its hand to tank hunting, but they are all secondary at it, and frankly equiping them for it means you are probably missing out on the possibility of flaming people, which is they way to go
A Dominion Squad with 4 meltas. :)
-981
looks like i'm havin a positive effect on you guys after all
yeh burn everything.
Got bad news for ya plague, all my standard sisters squads, my celestians and usually my serephim have always been tooled with flamers/heavy flamers, and a fair smattering of braziers, I have just avoided building up your ego by telling you
Actually a palatine with a jump and and master crafted inferno pistol can be an effective tank hunter. Considering you destroy a main battle tank you pay something around 70pts (no idea atm, at uni without a codex) and you gain at least 130pts+ in return. Not a good idea though, i prefer the exorcist idea but its just a counter comment to go against plague :p
I stand by my earlier statement, any sisters unit can be turned into a secondary tank hunter, but exorcists do it better, and all other units are better for anti infantry, so unless you are facing an armoured company, use 2 exorcists and ensure there is the odd eviscerator, inferno pistol or melta gun knocking around in case of emergencies
i like the palaitine idea cus that way ur not wasting a cano0ness and if she dies ya aint losingmuch
1 - 20 of 24 Posts
