The planned build for when I get an Autarch will be Fusion Gun + Powersword (not open to discussion), But seeing how GW sells the autarchs with either one separately, I was wondering what is cotained on either/the sprues.
Shiz, you might be better off cutting the chainsword off at the top of the hand and then gluing and pinning (if you can) the Diresword from the avengers - or alternatively why not use the power spear/glaive thing. Cut out the chainsword and drill holes into it and then attach the glaive - a little bit of fiddling but it sure beats having to bitz order from overseas or buying another autarch for no reason.
