1 - 2 of 2 Posts
Eldar: 1997
-Prince Yriel
TROOPS
-Dire Avengers*5: 92
exarch
double shuriken cats.
bladestorm
Wave Serpant: 145
Starcannons
Shurken cannon
spirit stones
-Dire Avengers*5: same as above
no cannon
no cannon
no cannon
HEAVY SUPPORT
- Fire Prism: 150
holo-fields
- Fire Prism: 150
holo-fields
-Fire prism: 150
holo-fields
Blade storm is a waste on 5 man units. It is very inefficient. Bladestorm on 10 man units is a lot better. I would drop one squad of DAs and their transport and upgrade the other squads with extra men. With your 3 points left over you should be able to make them all 9 men strong.
I would like to see spirit stones on the fire prisms. If you are going to bounce shooting off each other then only the exposed one needs spirit stones (or holofields for that matter) but it is hard to keep the others out of LOS for more than a turn or two.
The Dire avenger squad that contains Prince Yriel should have defend and shimmer shield rather than bladestorm. A good tarpit unit and the prince gives a much needed high strength combat boost.
Another way to save points would be to swap one fire prism for a falcon (costs an extra 25-40 points) and drop a wave serpent from one dire avenger squad. This should leave enough points to make 4 squads of 10 DAs in serpents and one squad of 5-6 in the falcon. Drop the exarch from the smaller squad and you can get spirit stones and underslung shuriken cattapults for more vehicles. 5 vanilla firedragons could also be used instead.
1 - 2 of 2 Posts
