1 - 12 of 12 Posts
· Registered
I was watching some friends play tonight and a cover save question came up. Here's the situation:
Squad of 10 banshees is shot at by a star cannon. 5 banshees are in LOS, the other 5 arent. 3 of the 5 visible are in cover. Now, the rule states that if the majority of models in the unit are in cover, the unit gets the cover save, if they arent, then nobody in the unit gets it.
The owner of the banshees argues that since only 5 were visible, and 3 of those 5 were in cover that counted as the majority, thus, they get the cover save. My feeling is that the rule states the majority of the unit must be in cover, doesnt say a word about LOS.
What do you think?
· Registered
I think that what he is saying makes alot of sense -- but I also think that by the rules, you are correct. AFAIK, line of sight is only relevant when it comes to removing casualties. Majority toughness, the mixed armour rules, and indeed cover are all dealt with using all models in the unit.
· Ender of Threads
Hmm. Here's something to think about.
"Sometimes a unit will be partially in cover. If there are more models that can be hit in cover than there are outside it, then the unit may make cover saves for the entire unit."
That's a direct quote from the rulebook (Pg. 25 of the Macragge booklet) on cover saves. Now, while it doesn't come right out in the open and say definitively yes or no, I'm reading that to mean you only consider the models that could potentially be hit. After all, if anything it's kinda crazy to assume that things that cannot possibly take hits in the first place should count as being vulnerable, right?
@LordCreampuff: Unless I missed a memo somewhere, the little Macragge booklet is exactly the same as the 4th edition BGB. It's the big book with all the fluff and extras cut away, leaving just the core rules. If I'm wrong, please correct me, but AFAIK they're the same.
· Registered
The Macragge rulebook is outdated by the 4th edition BGB. Use the new rules.
I agree with the above posts. LOS to models within a unit only comes into play when removing casualties.
· Registered
i would say yea they should get a cover save, just commonsense wise they should, it makes sense. I mean the majorety of the unit u can see is in cover so they should all get it, thats how we play it.
· Registered
Okay... so now I'm slightly confused...
We had always played that if you could see (for example) 4 out of ten, and the rest were behind blocking terrain, that unit could be fired on but only receive 4 casualties, and likewise only those four chould shoot back.
I had always assumed this was something we did to make it more realistic, but from what you guys are saying it seems this was actually the correct way of playing?
· Registered
Yeah, that's actually exactly how it's supposed to be played. Only models within line of sight may be removed as casualties.
Regarding the cover situation, yeah, it does look like they would get the cover save since the rules do specify that you only take the models that can be hit into account.
1 - 12 of 12 Posts
