Map = 14. All Along the Watchtower
First Turn = s0m3w0n
Lord Aldric Oliver's Milita
Bretonnian Lord (General) - 254 points
- Grail Vow, Virtue of Confidence, The Lance of Artois, The Grail Shield, Gauntlet of the Duel, Barded Bretonnian Warhorse
Paladin (BSB) - 114 points
- Virtue of Knightly Temper, Barded Bretonnian Warhorse
Paladin - 137 points
- Grail Vow, Sword of the Lady's Champion, Shield, Barded Bretonnian Warhorse
Damsel of the Lady - 105 points
- Dispel Scroll, Bretonnian Warhorse
Damsel of the Lady - 95 points
- Dispel Scroll
(9x) Knights Errant - 221 points
- Musician, Standard Bearer, Errantry Banner
(10x) Knights of the Realm - 264 points
(8x) Knights of the Realm - 216 points
(20x) Men-at-Arms - 115 points
(16x) Peasant Bowmen - 117 points
- Skirmish, Braziers
(3x) Pegasus Knights
(5x) Mounted Yeomen - 82 points
- Musician
(5x) Grail Knights - 250 points
- Musician, Standard Bearer, Banner of Defense
Total Points - 2245
Power Dice - 4
Dispel Dice - 4 (2 Scrolls)
Bretonnian Special Rules
All Knight units automatically are given unit champions free of charge.
Lance Formation - Bretonnian Knight units count ranks as 3 wide.
Command pushed back to the 2nd rank still operates as normal.
Damsels may be placed in the middle of the second rank and still cast, however, they do not have line of sight outside the unit when casting.
The Peasant's Duty - May use the Leadership of any non-fleeing Knight within 6" of the unit. Unit Standards that opponent captures do not give VP. (Applies to Men-at-Arms, Peasant Bowmen, and Mounted Yeomen)
The Knight's Vow - May ignore panic caused by friendly units with the Peasant's Duty. (Applies to all Knights)
The Grail Vow - Are Immune to Psychology. Always start the game with the Blessing of the Lady, regardless if the army prayed or not. All attacks made by models with the Grail Vow count as magical, however, this does not apply to the mount.
Blessing of the Lady - Affects all units with the Knight's, Questing, or Grail Vow. They receive a 6+ ward against all attacks, and a 5+ ward against attack S5 or higher. A unit or character loses the Blessing if they flee from combat (including breaking) or if they refuse a challenge they could have accepted.
Aura of the Lady - Damsels give the unit they are in Magic Resist (1).
Impetuous - If the unit is in charge range and has not declared a charge, they must take a Leadership test. If they test is failed, they must charge. If the test is passed, they may move normally. In addition, on the charge, Knights Errant and any character who has joined the unit are Immune to Psychology. (Applies to Knights Errant)
Living Saints - All Grail Knights count as unit champions for the purpose of accepting challenges.
Virtues and Magic Items
Virtue of Knightly Temper - For each attack that the Knight hits and wounds with on the charge (before saves) he may make an additional attack. Additional attacks cannot generate more additional attacks.
Virtue of Confidence - The Knight always issues/accepts challenges. In challenges, the Knight may re-roll all failed rolls to hit/wound.
Sword of the Lady's Champion - Always count the character's Strength as one higher than their target's Toughness, unless it would normally be more than this. At worst, the character will always wound on a 3+. Use the modified Strength to calculate Armor Save modifiers.
The Lance of Artois - Gives the user +2 Strength on the charge. Gives the user Killing Blow on turns where they charge.
The Grail Shield - Provides a 6+ armor save. Also increases the bearer's ward save from the Blessing of the Lady to a 4+ vs. all attacks. If the character loses the Blessing, he loses the ward save as well.
Gauntlet of the Duel - Any challenge issued cannot be refused.
Banner of Defense - The unit's ward save is increased to 4+ vs. all missles (including magical) of S5 or greater as long as they still have the Blessing of the Lady.
Errantry Banner - All Knights Errant gain +1 Strength (stacks with lances) on the turn they charge. Any unit with this banner suffers -2 to Impetuous tests.
ORC HORDE
Black Orc Big boss 218 pts
Martogs's best basha
Bigged's 'ed kickin boots
Amulet of protectyness
Light armour
General
Orc Big Boss 147 pts
Battle Standard Bearer
Mork's Spirit Totem
Choppa'
Orc Big Boss 110 pts
Ulag's akk'rit Axe
Enchanted Shield
Night goblin Shaman 100 pts
x2 Dispel scrolls
lvl 1 wizard
26 Orc Boyz 212 pts
Full command
Extra Choppa
25 Orc Boyz 205 pts
Full command
Extra Choppa
25 Orc Boyz 205 pts
Full command
Extra Choppa
25 Orc Boyz 205 pts
Full command
Extra Choppa
25 Night Goblins 170 pts
Full command
x3 Fanatic
Hand weapon and shield
Full command
x3 Fanatic
20 Black Orcs 298 pts
Full command
x6 Spear Chukkas
Total 2250 of Orcs for you to kill.
3 casting dice.
3 dispel dice (plus mork's spirit totem)2 Scrolls.
Martogs's best basha: +1 WS, Int and Str
Bigged's 'ed kickin boots: +1 Attack
Amulet of protectyness: Model uses same ward and armour save as model that wounded it.
Mork's Spirit Totem: Adds dispel dice no = to the number of ranks of that unit.
Ulag's akk'rit Axe: +1 Str in first round of combat, reroll to hit rolls
kinkeh secks pl0x?!
With the rocks impeding the orc advance the fanatic delivry service will be severly impaired in its placement. especially with the orc boys being on larger bases this will mean that there deployment area will be taken up with mostly them.
this leaves the Brettonians to specifically select its targets in a way to nullify the Orcs outnumbering advantage.
However if the brettonians are hit by the fanatics then they're will be hell. and the horsies will fall like flies.
I think it could be very very close but im going to have to go for the Orcs and Goblins.
due to the fanatics and the sheer weight of numbers they will be able to throw at the knight units.
King of Librarium's Tombs
Despite the Orc numbers, i dont think they will be enough to shut down the Bretonnian charges. Fanatics dont hurt now nearly as much as they used to, and given the good saves of the Knights and their Wards the should be fine mostly. The Pegasi will walk through the Bolters, even if just one pegasus is left alive when they get there. The bolters are damaging, but not very accurate.
Bearded Ninja
i think i'll throw my vote in for bretonians here. with a bit of baiting through the yeomen they should be able to get those fanatics out of the way quickly with minimal loss. the orc units, while numerous seem to lack the stopping power to impede those lances. more so with grail knights in the mix.
/botnobot/
I like Orcs and Goblins. One more unit of Knights might have swayed me. The rocks will split the Brets making tandem charges more difficult. O&G can put goblins up front to flee charges and open up counter charges, especially with a well-timed waagh. Orcs best men-at-arms in combat. Orcs just need to survive the initial charge, and they've got it in the long run, especially once those characters get in the mix.
And those bolt throwers can deploy, at least a couple of them, in the trees, keeping the pegasus knights from flying in. THey'd have to land and run in. And with six of them, you only need half of them to hit a turn to really hurt the knights.
O&G
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
I think that the big building will mess up Bret deployment more than the rocks will hinder O&G. Since the O&G will be able to set up across from the building they will be in better position for flank charging. The knights will cause damage on the charge but once again I think that the static res. of the O&G will allow them to weather the storm and after that numbers will prove telling. Quantity without quality will not win the day but there is enough quality(big orc mobs) in close combat to allow them to take the day. I see victory going to the O&G in a close battle.
Now 17% more helpful
This one will all come down to combat. How well can the Brets make it there without damage, how much damage can the fanatics and bolt throwers do in that time.
Since neither army has posted tactics, I would suggest the following will happen. The bolt throwers will probably aim for the largest knight block, or the Pegasus knights. If they are successful at maximum range, they will get 2 hits, probably 2 wounding rolls, and then it will be down to the ward save to stop the pegasus knights dying, (as the average roll on d3 is 2 wounds).
If they kill 2 of them, then the Brets have a real problem, as it will give the O&G free fire at the advancing Brets, damaging their charge. Less knights mean less kill, simple as that.
Without characters and average dice rolls, the Brets units of 9 knights, hitting a unit of 25 boyz, will win by 3+, meaning that the O&G, even with the BSB and general, will be struggling to stay together, and that is what will do it.
The Brets break 2-3 of the big units, then they have done there job. The grail knights will probably take on the Black orcs, and this will be the deciding combat, but without the fanatics killing a huge amount of knights, (and I believe the mounted yeomen will deal with them), I see the Brets taking this.
ninja out
I've had enough!
Behond, as I make my return!
Orcs for the win here, dude. Lack of speed is made for in huge numbers. Fanatics, at s5 armour peircing will stuff hurt. half a dozen spear chukkaz?! The night will be pegged back a rank bonus or two for sure, making the break on the charge harder.
So, the hode that can shoot seals it for me.
Regards, Tim
Banned
If the Bretts can make the fanatics flee, the game is theirs. But, unfortunately, they can't realistically send the Night Gobbos running, so the Fanatics will make burger of the Knights.
Also, such is the numbers that even one passed Break Test will spell doom for the Knights.
Thus, Orcies ftw.
-AFG
