Ok this squad needs some tweaks.necronmaster1 said:
First off the High Priest cannot have termie honours if he is wearing termie armour.
Second, take off the power fist (or weapon) and replace one with a BP to get another attack.
Although you have assault terminators it would be great if you took off the PW and PF and added Lightning Claws.
Personally Im not a big fan of terminators in a BA army, but if you really want them in, you should add more. Its an illegal squad because you have only 4 when the min squad size is 5. Try to free up some points and add 2 termies. 3 would be great.
I would take a crusader in this situation, because this list seems to be directed at a troopy army.
But if you think you lack anti tank, then this would be a good support choice.
If you really like BA dreads this much you should play FT!
Ok first off moriar is illegal, he is actually 144pts not 103.
Second, if your going to field furioso I always find it better to add Heavy Flamers for the +10 pts.
Good, but try to get in some meltaguns if these marines are going to be takinga ride in a rhino.
Im assuming these are holding the 2 tac squads above.
These rhinos are equiped nicely.
Very nice squad, although I would replace the power weapon on the vet with a power fist.
Perfect! :yes:
Very good, although you didn't specify whether it is a MoS or a Reclusiarch.
The scouts need a specialty, whether its CC, snipers, or just supporting fire with bolters and a heavy bolter.
Same advice for the marines as list 1.
Good Rhinos.
The melta bombs are not necessary. I would remove them. Again, replace the PW with a PF; this will give you the tank busting capability that the melta bombs did.
Again, Perfect.
Overall, I think (with the modifications) the second list would be alot better than the first. Although more bodies would be nice for more DC. With those two Chappies there is a possibility that you can get 17 DC marines, 5 with PW/PF! I really like the assault squads and the Baal preds, they will be key in long lasting matches. 30 shots, 12 Assault cannon, 18 heavy bolters = Godly. :O
Good luck
HPA
