Hey all, writing this list so i know what to buy. Would like C&C so i dont do any stuipd conversions!
HSO
Power sword
Plasma Pistol
Carapace Armour
Veteran
Close Combat Weapon
Las pistol
Veteran
Close Combat Weapon
Las pistol
Guardsman
Vox-caster
Guardsman
Medic
HQ Total 112
Infantry Platoon 1
JO
Power Sword
Guardsman x 4
Vox-caster
Auto Cannon
Total 75
Squad Alpha
Sergeant
Close Combat Weapons
9 x Guardsmen
Heavy Bolter
Melta Gun
Vox-caster
Total 85
Squad Bravo
Sergeant
9 x Guardsmen
Heavy Bolter
Grenade Launcher
Vox-caster
Total 83
Troop 1 Total 226
Infantry Platoon 2
JO
Power Sword
Guardsmen x 4
Vox-caster
Auto cannon
Total 75
Squad Alpha
Sergeant
9 x Guardsman
Missile Launcher
Grenade Launcher
Vox-caster
Total 88
Squad Bravo
Sergeant
9 x Guardsmen
Missile Launcher
Plasma Gun
Vox-caster
Total 90
Troop 2 Total 251
Leman Russ
Hull mounted Heavy Bolter
Heavy Bolter Sponsons
Total 155
Army List = 748pts
Thanks
Deathodia920
Shrug, k...
not gonna try to change the direction your heading in so here's just some suggestions to add with what you're doing.
since you want to send your hq command squad into the fray, might as well give them a priest and/or commissar since the advisor rule defaults them to that squad anyways. otherwise i'd suggest to switch this command squad role out with that of your infantry platoon command squad, and adding a standard bearer since only the hq command squad can get that and it's invaluable to your line squads that plan on providing fire support to the charge.
but, if the vox-caster system is being used because you plan on being spread out, i'd upgrade the command to have a master-vox, and add in light infantry so you can truly spread out to range that would make the command bubble ineffective, your guys are footslogging it and it doesn't look that they'd be able to get about the field in any quick manner anyways so why not just start them out spread across the board infiltrated. that is, unless you're using the drop troop doctrine, then just disregard that.
i gather from your point totals that 'close combat weapons' meant just what your sgt's were armed with and not the doctrine (which would have had to be added into all the guard infantry units). the heavy bolter/melta-gun isn't a good combo, ones anti-infantry long range, the other is anti-tank,short range, i'd consider changing the melta-gun to something more complementary.
or, if you're looking for some advancing-mobility, maybe trade out the second platoon for an armored fist squad or mount one/both of your command squads in chimeras to move with the leman russ (to which i would add extra armor, and smoke launchers if you got the points left over).
at 750 and even moreso in larger games, how about a small unit of ogryns or some rough riders (which i love to death ever after the first time using them, a small squad of 5 took out 10 assault marines trying to jump across the field on my flank). though for bigger games maxed out squads of 10 are recommended for either (and mounted in a chimera w/ bone'ead for the ogryns)
also, for a close combat oriented guard, you might want to consider implementing die-hards, hardened fighters, and/or warrior weapons in some sort of combination with your list that would work for you.
- If you're using your Comand squad for melee, as you rlist goes 1) Drop the Vets - the points for 1x extra attack would be better spent on flamers (+1 attack if it gets to his turn in h/h, or a template that doesn't rely on BS first). Or 1x flamer and frag grenades (Really important for charging!)
- true, however not totally unendorsable, just unorthadox. I'd use a ML or autocannon if you have a penchant for Meltas, or plasmas with HB's but it's up to you.
- I hope you're going to keep the LR as a anchor in your gunline right? Chimeras with all the trimmings are just over the cost of 2x sentinals w multilasers. You want more scoring / targetable units in this scale in my oppinion
Shrug, k...
a chimera and a squadron of sentinels are in the same boat in that they both are almost ridiculuously easy to kill to determined squad of devastator equivalant units (deq!?! shrug), except that at least with the chimera, you can have infantry huddling to stay out of los with the chimera wreckage (which the squad is a scoring unit while the chimera wasn't capable of scoring)
ok, imo i love sentinels, and i would somehow like to see it feasible in which these where almost a staple to ig mobility, they're just awesome models (especially when converted just right like those walkers the stormtroopers had on the wookie planet in star wars), but these things are just asking for to almost be shot at, and sadly 1-2 squads of bolters could kill off a squadron of these guys. so although they add mobile firepower, they're very so much mobile-dead unless used just right in the isolated flank that the enemy used and had only that one unit there that could get butted out by that sentinel squadron.
