1 - 17 of 17 Posts
Hello everyone, I'm new to Warhammer and thus Wood elves aswell, me and a few other friends decided to all start playing these are the armies they chose:
Hordes of Chaos
Vampire Counts
Dark elves
High elves
Wood elves aka me
So after reading the Army book a bit and being new to the game. I made the following list and was wondering if you guys could take a look at it and maybe say what I did right and what wrong. Well without further ado here is the list:
Spellsinger Lv1
2 Dispell Scroll 140
Wood elf Noble
Waywatcher Kindred
Hail of Doom Arrows 140
Glade Guard 10
Musician 126
Glade Guard 10
Musician 126
Dryads 8
No upgrade 96
Dryads 8
No upgrade 96
Wardancers 7
Full Command 147
Waywatchers 6
Shadow Sentinel 128
Total points 999
My main strategy is to induce as much damage to my opponent with shooting until either I come close to them or they come close to me for my Wardancers assisted with Dryads to pick off my enemy units one at a time. With a Spellsinger doing assisting Magic, for that I picked Treesinging and The Hidden Path. While at the same time my Waywatchers with Noble will harass the enemy with my Glade guard.. So this is my List I hope it's any good and any advice will be appreciated. =)
Edit: Updated the list
Hero's
Wood elf Noble
Waywatcher kindred
110 points
You have better options than this guy. An alter noble with Hail of Doom Arrow and Helm of the Hunt is a powerful choice at this level. A Wardancer with Blades of Loec, or Annoyance of Netlings is another nice option. If you are set on the waywatcher, give him some kind of ward save.
Spellsinger
Level 2
125 points
Level 2 won't do much for you. If you keep him, make him a 1st level, with 2 dispel scrolls. I would probably swap him for a branchwraith upgraded to level 1 with a cluster of radiants.
Core units
12 Glade Guard Full command
168 points
Never use standard bearers on your glade guard. You won't win combat with it and the +1 doesn't generally help, so you just end up giving your opponent victory points. The champ isn't great unless you have the points and you can't put them any place else. And 10 is a good size. Only go up if you don't have anyplace else to put the points.
10 Dryads
120 points
Slightly too big. 8 is generally the best number.
10 Dyrads
120 points
See above.
Special Units
10 Wardancers Full command
237 points
7 or 8 is generally the best number for these guys.
Rare units
6 Waywatchers
120 points
Fine
One thing I don't understand, you said you picked your spells, but spells are rolled randomly at the start of the game. You are only allowed to switch one for the first in the list, treesinging in this case.
I think if you cut some things down to size, you might be able to throw in another unit. For wood elves lots of small units work better than fewer big units I find.
Good luck, and hope this helps,
SirKently
Ah okay, I didn't know you can't choose your spells good to know then. ^^ And thanks for the tips.
Edit: Sorry for the double post but I cant seem to find a way to delete this post =(
New list ^^
Spellsinger Lv1
Wood elf Noble
Waywatcher Kindred 110
Glade Guard 10
Musician 126
Glade Guard 10
Musician 126
Dryads 8 96
Dryads 8 96
Wardancers 8
Full Command 165
Waywatchers 6 120
Total points 979
That leaves me 21 points left.. Any good item for 21 points or something?
Hmm.. I see and the Hit is automatically the hit of my Waywatcher noble?
So this list might better then maybe..
Spellsinger Lv1
Wood elf Noble
Waywatcher Kindred
Glade Guard 10
No upgrade
Glade Guard 10
No upgrade
Dryads 8
No uprgrade
Dryads 8
No upgrade
Wardancers 8
Full Command 165
Waywatchers 6
No upgrade
Total points 997
This makes sense in term of maneuverability, but what are your experiences once they hit closecombat? Won't they flee rather fast after minimal losses already?
Yeah, they will flee rather easily if you go one on one. The trick is to get your units positioned so that you have at least 2 and hopefully 3 units attacking together against an opponents unit. Works even better if at least two of your units cause fear, say dryads and wild riders. With wood elves you don't want a combat that lasts, you really need to break your opponents unit on the charge or usually you will be in trouble.
SirKently
Thanksfor your advice. :)
The waywatcher noble is very expensive for what he will do, he will do hail of doom and then not much else for rest of gmae. also having your general scout in a a small unit of waywatchers can be dangerous. An alter noble with great weapon, light armour, sheild, hail of doom arrow and helm of the hunt comes in at 158 points only 18 more then your waywatcher hero. Drop a waywatcher (these guys are great but quite expensive and bigger units mean harder to setup) and take alter hero. This hero will be able to do hail of doom arrowand then will also give 5 strength 6 attacks at WS 7 on the charge.
P.S in your list you have 8 dryads with no upgrade and they are listed as -- many points. This is'nt allowed on the forums only include points of a unit if they have upgrades.
1 - 17 of 17 Posts
