Shadow raiders speed list
2000 points
Dracon
Splinter rifle
Soul seeker ammo
Poisoned blades
Shadow field
9 warriors
Dark lance x2
Raider
Slave snares
Night field
Plasma grenades (all)
264
Raider squad
10 warriors
Shredder
Dark lance
Raider
Slave snares
Night field
Raider squad
10 warriors
Shredder
Dark lance
Raider
Slave snares
Night field
Elites
10 Mandrakes
Fast attack
Reaver Jetbike squad
10 jetbikes
250
10 jetbikes
250
Hellions x10
Upgrade one to succubus
196
Heavy support
10 scourges
4 dark lances
260
Ravager
Night shield
125
Ravager
Night shield
125
2000 total
My known enemies (for friendly games until I get the hang of 40k and dark eldar) Tau, Orks and maybe Black Templar. I may also drop a unit of jet bikes and get a haemonculus with stinger and scissorhand, 9 grotesques and a raider or just make it a 2250 list. So far all I own is a raider squad and the Dracon. Thank you for any help.
-crazyhorse
If your are just starting out with 40K and Dark Eldar (DE), I suggest you start a point value much lower. 500Pt to get started with 40K by learning the basic rules. And 1500Pt to learn more about DE and how to use them. Personally, I'd start to learn about DE at 1000Pt, but anyone could argue that in the lower point games you can't win very much. Which is fine in my opinion because the goal is just trying to learn the game.
As for your list, need more close combat oriented units (more wyches).
Banned
All right im going to be honest with you, this list made me vomit.
hellions suck
scourges suck
remember you cant move and shoot heavy weapons so give raider squads splinter canon + blaster.
shredders suck.
never give your dracon a splinter rifle he HAS to either have a punisher or agoniser setup, unless you put him on a jetbike then power weapon could work.
soul seeker ammunition is garbage wargear as it can only be combined with a splinter pistol or blaster for dracon but its not worth -1 attack. if you really want a shooty dracon go for blaster with soul seeker then maybe if he kills a tank he will do something...
im not a fan of slave snares as i think their worthless.
night field only for ravagers, raider will be closing in anyway for blaster/rapid fire range but ravagers can try to stay out of range of some guns kind of, though i dont usually use any DE vehicle wargear except horrorfex and disentegrators.
mandrakes are not meant for serious play.
reaver jetbikes arent the best close combat squad, you could drop both of these for 2x wych squads.
i reccomend dropping scourges for 2 warriors squads of 10 with 2 dark lances.
ravagers cannot have all dark lances it just doesnt work, you need to keep it moving so give it 2 disentegrators and a dark lance or all disentegrators.
I wouldnt reccomend grotesques they dont perform too good, however i do reccomend some haemonculi on skyboards, with destructors you have some flamers with a 50% chance of ignoring marine armor.
I dont want to seem mean or something but this list isnt gonna win much.
@ Sesshomuronay
No need to be so hostile.
2000 points
Dracon
Splinter rifle
Soul seeker ammo
Poisoned blades
Shadow field
9 warriors
Dark lance x2
Raider
Slave snares
Night field
264
This list unit seems a bit grab bag. It seems to be built for both shooting and assaulting while doing neither effectively. You need to trim down this to a single role (either shooting or assaulting). Since it is your HQ squad I suggest assault since the archon is one of the best assault HQs in the game when upgraded. As the other guy said, poisoned blades are generally less then optimal unless you are fighting Nid-zilla lists at low point value games and need to skim points. Generally, the agonizer is the same thing since instead of wounding on a 2+ and dealing with a 3+ armor save, you 4+ to wound and don't deal with any armor save at all.
The reason I suggest against shooty is because the archon has some of the worst ranged ability of any HQ. Soulseeker ammunition is good as a point waster but not much else since our splinter guns have low AP and most things armor saves are better then their cover saves. In addition, the dark lances or the raider will go to waste since you can't move the raider with the guys inside and still fire the squads dark lances since it counts as moving for them. So either you are a sitting duck or you are wasting points. If you want a dark lance firing squad, get a non-raider warrior squad of 10 warriors with 2 dark lances and nothing else. Thats 100pts and does the same thing and doesn't waste the archon on something he isn't good at.
Warriors are ok for an assault list, just don't expect them to do anything other then act as extra wounds for the archon. I suggest making the dracon and archon (since it is a high point game) and giving him combat drugs. Don't worry about the wounding thing it does, it will rarely happen and matter even less often.
Raider squad
10 warriors
Shredder
Dark lance
Raider
Slave snares
Night field
Raider squad
10 warriors
Shredder
Dark lance
Raider
Slave snares
Night field
The darklance + raider thing again, so I won't cover that much. Slave snares are fine although I've personally found them to be better on paper then in practice since things still get their armor save against it. Shredders are fine weapons if you are fighting against imperial guard with close order drill or bad players of any other army. A good player will spread his guys out so that you'll get at most guy. Even at that, since it doesn't have AP, they still get their armor save. A blaster in most situations is better since it has the same range and is useful against basically everything.
10 Mandrakes
Mandrakes are, well... mandrakes. They have a cool deployment method but unless you are abusing it in some way, they aren't scary and don't do much. The most you'll get out of them is worrying an opponent that hasn't seen them before. Of all the elite choices we have, the only really good ones are Wyches and Warp beast packs. If you already bought your models and don't have either of those, you are probably better off not running them or switching to an army of shadows build (ie, only mandrakes on the field at the start of the game and then deep striking everything else).
Fast attack
10 jetbikes
250
10 jetbikes
250
Nothing wrong with these, but i notice a lack of the succubus and you didn't give them any blasters. As it stands now, they are too generic to do a whole lot of good. A pair of blasters in each will make them excellent tank hunters (or terminator hunters) and a succubus armed with a power weapon or agonizer will make them great for striking down deep striking squads and attacking firing lines.
Hellions x10
196
These are one of those units that were good to decent in 3rd edition and then got nerfed a ton when 4th ed came out because of the change to rapid fire rules. As is, they look good on paper but don't do a whole lot in practice. Try them out, you may have better luck with them but you should probably cut them out for another jetbike squad or something else.
Heavy support
10 scourges
4 dark lances
260
Nothing wrong with this per se since I've seen them used well before. However, keep in mind that if you deep strike them in, they can't fire since they count as moving.
Night shield
125
Ravager
Night shield
125
As the other guy said, you can't fire all the dark lances if you move. And if you don't move you die.
Grotesques aren't that great and I suggest against them. Yeah, they have two wounds but the lack of an armor save REALLY hurts. The stinger is also a weapon that s better on paper then in practice and you should replace it with a destructor.
Against orks you want LOTS of fire power: Not high strength, just lots of shots because there should be a ton of them (expecially at this point value). Against black templar, have fun. They are short range and you have better assault guys and better shooting. If they field a Land Raider Crusader try to trick him in to placing it on one of the corners of the map and then stay far away from it since it will be hard for you to kill.
The haemonculi on the skyboard doesn't work since you can only equip guys on skyboards with the glaives and haemonculi can't equip glaves since they aren't haemonculi weapons.
Banned
@ Sesshomuronay
actually it does work, it doesnt say they have to take hellglaives and by all means they can have skyboards with a destructor.
Oops, sorry. I was remembering it backwards: If you have a hellglaive you must have a skyboard but not the other way around.
