1 - 13 of 13 Posts
Yah. This might be in the wrong forum, but does anyone know how to convert a grey knight terminator to be using a storm shield and thunder hammer?
I don't think they can have a Thunder Hammer and Storm Shield. But, if you want, I would take the Hammer and Shiel arms, cut them at the wrists or elbows, and do the same with the GK termie.
DON'T SPAM! (Someone's getting a warning)
The Sholder Shield might work, but I know that the GK Termies CAN'T have Storm Hammers/Shields.
And you need to brush up on your codex. They can actually, but GW never made a minature for it.
I was thinking of clipping the halberd arm at the halberd to get it off, then gluing a hammer head onto it. Storm Shield is the problem though...
they are allowed to have T hammer& storm shield.....
about the conversion....
cut off the thunder hammer from the s marine terminators and take a sword arm and cut off the sword from the grey knight terminator and putty it on...
slice off the storm bolter and putty and glue the storm shield on......
i might try one :)
Chin man (4-4) that is called spamming and u shoulent do it and as i was saying termis can have thunderhammer and storm sheild and u can upgrade there little sheid to a storm shield mut u would not be able to use the storm bolter .
I have several.
Use the archive Thunder Hammer and Storm Shield arms.
They look suitably baroque enough to match the overall appearance of the Grey Knights.
I think what you are sugesting (regnar) would probly work . In fact im going to five a couple of my temis thunder-hammers , allthough im still not sure wheather or not you can use there little shouler sheild as a storm sheild , if anyone knows could you pleze tell me :D
I think your best bet would be to try this:
Thunder Hammer: Chop the Halberd off above the hand, and pin the top of Coteaz's TH to it, OR chop the halberd hand off entirely and use Coteaz's
Storm shield: Use the regular Termi SS arm from the elbow down, (replace the Storm bolter forearm with it). As for a Storm shield, ever thought of using the big gun shields from the Hurricane pattern bolters on the LRC? They're suitably big and imposing
just a thought
-neutron
1 - 13 of 13 Posts
