I was putting my devilfish together, and a good deal of glue got on the front barrel of its burst cannon. Does anyone know of any good glue solvent (well, other than glue-specific solvents) or should I just use a knife to scrape it off? It looks pretty bad, with the white gunk and all.
Well, you need to specify what type of glue for starters. White glue should wash off with enough hot water. Polystyrene glue is impossible to remove, it sorta welds plastic together, super (cyanoblahblah) glue I have no idea, maybe acetone - I would personally clean it up as much as possible with an exacto blade and then fix any gouging with green stuff. I'm pretty inexperienced though. ;)
It's citadel miniatures cyanoacrylate glue. Yeah, I had a feeling i'd need to just scrape it off. ah well.
