Look at the underside of the base
--ok
now see those "holes" punch one of those bad boys through.
I used a small screw driver, but what ever works
((id also fortify with some glue))
Now shove the plastic shaft in the hole and connect the other to the underside of the eagle!
Viola!
a freshly mounted eagle.
Other options include stubbornly glueing the shaft to the base, which tends to not work so well. :/
hope that works out for you.
