Probably the best advice I can give is the immortal words, "don't panic". If you're afraid of his knights you'll over estimate the danger they represent and could end up causing big problems for yourself. For a start, set up your bolt thrower on the other side of the table from them - if you can hit them in the flank once or twice they're nothing but victory points. If you can, use your shadow warriors to march block them as well, then even your infantry will be able to outmanouvre them.
Against such heavy armour the bolt thrower will come in very handy, I'd suggest you give your mage seer, jewel of the dusk, curse of arrow attraction and fury of khaine if you have the points. Curse of arrow attraction coupled with the bolt thrower could take down a couple of knights before your opponent realises you're planning to shoot at them (hint - put the bolt thrower on the table facing another target unit, you'd be amazed how many people fall for this). If not, it'll mow down a good few warriors. I can't really give you much more detailed advice without knowing your opponent and his list.
It sounds like it'll be a tough game, but you'll stand a chance if you can slow down his advance and get a few flank charges in. Good luck.
