Hi guys i try to use perfect grammer, but this is not school this is the net so it hard to be proper.
Just out of interest, why do you say this?
I generally try to use whatever language I'm using as properly as possible, but then maybe this is just me.
Thanks for trying though, it is much easier to read your post.
Personally I do use GW inks, but generally not for shading. I tend to find that they leave a gloss finish, which always seems a little odd, considering you're generally shading the recessed/dark areas of a model.
For washes, I tend to mix my own.
As far as 'making' washes goes (good to see you're trying some of the advice you've been given), I would reccomend starting off at a 70 : 30 water : paint mix. If the paint still acts too much like 'paint' (as in, you can't see much of what you're painting it over) then you need too add more water.
When you're mixing it up, use a pallette, and simple use your brush as a rough measuring implement. Put down 3 blobs of paint on the pallette, then 7 blobs of water. Mix until the paint has a single consistancy, then try it on a model.
Something I find very helpful with washes is using a piece of tissue paper to test the consistancy of the mix. Simply put a dab of the wash onto the paper using your brush. If it is sufficiently thin, it should easily spread out over the paper, going slightly transparent. If it is too thick, it will 'bead' up, forming a blob, and hardly spreading at all.
The best way to figure these things out is, at the end of the day, to experiment. Play with a few of your models, and see what happens.
-t.
