When it comes to Live streaming TV’s, the Fios TV can be said to be one of the best out there. When you purchase the Fios TV package, the Fios remote control is one of the hardware you will get in your package. You will need to program your Fios remote to your TV for you to enjoy the Live Streaming service. There are two methods you can follow through to program your Fios remote to your TV. You will need the Fios remote codes for the first method. This post listed the Fios remote codes for most TV brands. All you need to do is to go through the post, find the code for your TV brand and proceed to sync your remote to your TV.
What you need to program your Fios Remote to your TV
. Fios Remote Control
. Set-Top Box
. The TV you wish to program.
How to program your Fios Remote without Fios Remote codes
This method works best for you if you don’t want to go through the process of searching for the Fios TV codes. But you its best to use the manual code method. It is easier and faster.
Step 1. Switch on the TV you want to sync to your remote. Simply press the ‘Power Button’ on your TV.
Step 2. Ensure you switch on your Fios Set-up box.
Step 3. On your Fios remote, you will find the LIVE TV and OK buttons. Press and hold down both buttons for several seconds. Release the buttons when the tiny LED light on your remote blinks and remains on.
Step 4. The next step is to find the ‘Play’ button on your remote and press the button. You will need to hold down the button until the steady tiny LED light blinks. What happens while you press down the PLAY button is that the remote will go through the database of codes to find the correct code for your TV brand.
Step 5. Once it gets the correct code, your TV will turn off. Only release the Play button when that happens.
Step 6. Press the ‘TV Power’ button on your remote to switch on your TV. You can use any button to test if the remote was correctly programmed. For instance, you can use the Vol- and Vol+ button to reduce or increase the volume on your TV. Once it works, viola, the next step is to save the settings.
Step 7. To save the codes, press the ‘OK’ button on your remote. The Tiny LED light will blink a couple of times. Viola, you have programmed your remote to your TV using the code search method.
How to program your Fios Remote with Fios Remote codes
This is the manual way to program your Fios Remote to your TV. Click this page to find the correct code for your TV. With the codes, proceed to the steps below to do the syncing process.
Step 3. On your Fios remote, you will find the 0 and OK buttons. Press and hold down both buttons for several seconds. Release the buttons when the tiny LED light on your remote blinks and remains on.
Step 4. Enter the correct code for your TV brand using the number pad on your remote. The code do appear as 3-digit numbers. But for most TV brands, you will have to add a 0 in front of the numbers. After you enter the code, press the CH+ button a couple of times.
Fios TV Remote codes for Popular TV Brands
Admiral TV CODES = 0120, 0490, 3001, 3027
Akai TV CODES = 0057, 0087, 0699, 0729, 0839, 3002, 3182, 3219
Apex Digital TV CODES = 0183, 0775, 0792, 0794, 0906, 3183
Changhong TV CODES = 0792
Citizen TV CODES = 0057, 0087, 0119, 0205, 3005, 3006, 3009, 3012
Daewoo TV CODES = 0119, 0205, 0478, 0650, 0688, 0699, 1688
Durabrand TV CODES = 0198, 0205, 0207, 0490, 1061
Element TV CODES = 3264
Emerson TV CODES = 0181, 0198, 0205, 0207, 0263, 0490, 0650, 3005
Fujitsu TV CODES = 0710, 0836, 0880, 3013, 3159, 3160, 3162, 3163
GE TV CODES = 0074, 0078, 0205, 0478, 1174, 1374, 1474, 3000, 3003
GoldStar TV CODES = 0057, 0205, 3004, 3005, 3008, 3025, 3026, 3202
Hitachi TV CODES = 0172, 0205, 1172, 3005, 3008, 3039, 3044, 3180, 3198
JVC TV CODES = 0080, 0758, 1280, 3008, 3017, 3019, 3070, 3096, 3097, 3101
LG TV CODES = 0205, 0727, 0883, 1205, 1292, 3004, 3145
Magnavox TV CODES = 0057, 0081, 0205, 0733, 0829, 1281, 1481, 3005, 3006, 3018
Mitsubishi TV CODES = 0120, 0177, 0205, 0863, 0895, 1277, 3004, 3005, 3075, 3091
Olevia TV CODES = 3131, 3226, 3231, 3232, 3233
Orion TV CODES = 0263, 0490, 1490, 3011, 3031, 3090, 3204
Panasonic TV CODES = 0078, 0277, 0677, 1437, 3003, 3017, 3018
Philips TV CODES = 0081, 0205, 0717, 1181, 1481, 3003, 3006, 3008, 3018
Pioneer TV CODES = 0193, 0205, 0706, 0893, 3005, 3029, 3108, 3115, 3157, 3165
RCA TV CODES = 0074, 0117, 0205, 0706, 1074, 1174, 1274, 1374, 1474, 1574
Samsung TV CODES = 0057, 0087, 0205, 0729, 0793, 0839, 0841, 1087, 3004
Sharp TV CODES = 0120, 0205, 0518, 0715, 0716, 0878, 3005, 3008, 3021
. Set-Top Box
Read more: Endless Running Games Online: Geometry Dash
