Command Squad-50
Heavy Bolter-10
=60
Veteran Squad-70
3 Melta Guns-30
Grenadiers-30
Chimera-55
Heavy Stubber-10
=195
Veteran Squad-70
3 Plasma Guns-45
Grenadiers-30
Chimera-55
Heavy Stubber-10
=210
Veteran Squad-70
3 Plasma Guns-45
Grenadiers-30
Chimera-55
Heavy Stubber-10
=210
Veteran Squad-70
3 Flamers-15
Chimera-55
Heavy Stubber-10
=150
Veteran Squad-70
Heavy Bolter-10
=80
Veteran Squad-70
Heavy Bolter-10
=80
Armoured Sentinel-55
Missile Launcher-10
Hunter Killer Missile-10
=75
=1000
Edit out the individual upgrade point costs. It'll get you in a lot of trouble here.
Grenadiers is very rarely ever a good doctrine to choose, and at 1000 points, you don't need them. Drop the doctrines. While you're at it, drop the heavy bolter and heavy stubbers.
For some reason, you've got two veteran squads with heavy bolters. I'm not sure why this is, you'd be better served using these points and taking a platoon, and then giving them autocannons. Not only would you have more scoring units, but you'll have much heavier firepower.
You're also giving one veteran squad Flamers, which is an absolute waste of points. Drop that squad entirely. If you want flamers, take the Platoon command squad from the platoon I suggested above and give them 4 flamers, and throw them in a chimera. Now you've got a platoon, and two Veteran squads. You need at least three more melta guns, so swap one of the veteran squads to melta guns. With the points left over you can get some more vehicles.
Imperial Guard 1000pts Redone
Command Squad-60
Autocannon
Veteran Squad-155
3 Melta Guns
Chimera
Veteran Squad-155
3 Melta Guns
Chimera
Veteran Squad-170
3 Plasma Guns
Chimera
Infantry Platoon-50
Platoon Command Squad
4 Flamers
Infantry Squad-60
Autocannon
Grenade Launcher
Infantry Squad-60
Autocannon
Grenade Launcher
Infantry Squad-60
Autocannon
Grenade Launcher
Infantry Squad-60
Autocannon
Grenade Launcher
Heavy Weapons Squad-75
Autocannons
Autocannons
I am doing no heavy vehicles in 1000pts but in my 1500 i will be having more vehicles and infantry
Command Squad-60
Autocannon
Veteran Squad-155
3 Melta Guns
Chimera
Veteran Squad-155
3 Melta Guns
Chimera
Veteran Squad-170
3 Plasma Guns
Chimera
Infantry Platoon-50
4 Flamers
Infantry Squad-65
Autocannon
Grenade Launcher
Infantry Squad-65
Autocannon
Grenade Launcher
Infantry Squad-65
Autocannon
Grenade Launcher
Infantry Squad-65
Autocannon
Grenade Launcher
Autocannons
Autocannons
I strongly suggest the addition of commissar(s) for foot platoons. Ld 9 helps a lot for orders and stubborn is invaluable in assaults.
