1 - 12 of 12 Posts
ok I just designed a IG army and I need to know if I'll just get punked... So here is the possible list(any suggestions are welcome) bear in mind I already have the storm troopers, ogryns, ratlings, and 60 IG shock tropers...
HQ 103pts.
Senior officer
Standard bearer
Master-vox caster
Medic
Guardsmen flamer
Elites
Ogryns 135 pts.
Ogryn Bone 'ead
Ogryn X4
Ratling Squad 55pts.
Ratlings X5
Strom Troopers in Chimera 199pts.
Storm trooper sergeant
storm trooper flamer
storm trooper grendade launcher
storm troop X6
Chimera Heavy bolter / hull heavy bolter
HQ platoon #1 45pts.
Junior officer
Vox caster
guardsmen X2
Squad #1 96pts. frags
Sergeant
Auto cannon team
Vox caster
guardsmen flamer
Guardsmen X5
Squad #2 93pts. frags
sergeant
Heavy bolter team
vox caster
guardsmen grendae launcher
guardsmen X5
Squad #3 106pts. frags
sergeant
lascannon team
vox caster
guardsmen flamer
guardsmen X5
HQ platoon #2 45pts.
Junior officer
vox caster
guardsmen X2
Squad #1
Sergeant
Auto cannon team
Vox caster
guardsmen grenade launcher
Guardsmen X5
sergeant
Heavy bolter team
vox caster
guardsmen X5
sergeant
lascannon team
vox caster
guardsmen flamer
guardsmen X5
Fast Attack
Sentinel Squadron #1 205 pts.
Sentinel lascannon armoured crew compartment
Sentinel autocannon armoured crew compartment
Sentinel Squadron #2 205 pts.
Heavy Suppourt 165pts.
Lemen Russ Battle Tank Hull mounted lascannon Sponson heavy bolters
well there u go I'm tryin to get as close to 1750 as possible. so please help me. and remember I on limited funds. ohhhh.... and I have an eldar army for sale if anyone is intrested drop me an e-amil at [email protected]
Son of LO
For the most part your army list is really excellent. I like everything in fact except for the unusual amount of sentinels with lascannons. If you really want that many lascannons, then drop three of the sentinels and add a lascannon squad. The reason for this is that you can HIDE the lascannon squad behind other units of troops but you can't hide the sentinels and they will die quickly. Also, if you really like sentinels, they are much more cost effective with either autocannons or heavy flamers. Also, the armored crew compartment won't save you for very long, trust me, I've been playing IG for several years now.
Another good substitution is removing those sentinels for a Basilisk. It really is the best tank the Imperial Guard has to offer. AND, you'll have just enough points left over for a squad of Autocannons. Not to mention one Basilisk costs less than three sentinels these days.
So other than replacing the sentinels with heavy weapons squads (Heavy Bolters and Autocannons are the BEST) I think your list is really nice. Also, if you already have the models or can afford it, then try to put a heavy weapon in EVERY squad including the command squads. I find that missile launchers are the best in command squads personally.
Also, you didn't mention it so I thought I might add this bit, but with that many ground pounders in your army, the Sharpshooter doctrine works wonders. I've been using it for 6 weeks now and my kill ratio has gone way up.
WOW! For a new comer to IG you have large force. Your force covers all shooting and close combat needs, but for the most part i agree with Hourglass. He pretty much summed up what you could do to improve it. Go with autocannons, sharpshooters, heavy weapons teams and a basilisk.
k so keep the lemen russ.... drop the armoured crew compartments... add a basalisk.... and add more heavy weapons teams.... sounds good I'll change the list and get back in a while
how's this? and if u have a suggestion for spending the other 73 points please tell me...
HQ 103pts.
Senior officer
Standard bearer
Master-vox caster
Medic
Guardsmen flamer
Elites
Ogryns 135 pts.
Ogryn Bone 'ead
Ogryn X4
Ratlings X5
storm troop X6
Junior officer
Vox caster
guardsmen X2
Sergeant
Auto cannon team
Vox caster
guardsmen flamer
Guardsmen X5
sergeant
Heavy bolter team
vox caster
guardsmen X5
sergeant
lascannon team
vox caster
guardsmen flamer
guardsmen X5
Junior officer
vox caster
guardsmen X2
Squad #1 96pts.
Sergeant
Auto cannon team
Vox caster
Guardsmen X5
sergeant
Heavy bolter team
vox caster
guardsmen X5
sergeant
lascannon team
vox caster
guardsmen flamer
guardsmen X5
Heavy weapon platoon
HQ 45pts.
Junior officer
vox caster
guardsmen X2
Anti-tank squad 110pts.
Lascannon
Lascannon
Lascannon
Fast Attack
Sentinel Squadron #2 150 pts.
Sentinel autocannon
Sentinel autocannon
Sentinel autocannon
Basilisk indirect fire 125pts.
Hi, Mr.Death, Ive noted some possible errors in and your points calculation and also included some positive suggestions for your army below.
"HQ 103pts.
Perhaps i am wrong but my total points regarding that squad comes to 114. Remember that to become a Medic or a Standard Bearer the Guardsman MUST be upgraded to a Veteran. Additonally the master-vox must be upgraded from a vox-caster meaning their points are added together to reach the final cost [the cost of the Master-Vox in on top of the vox-caster].
I also noted the 9 man Stormtrooper Squad is listed at 199, when I calculated 189 points.
Squad #1 in Platoon #2 @96pts. I calculated 88 points. (No frags?)
Also, i am not sure of the role you have planned for your Heavy Weapons Platoon but i would recommend eliminating the Platoon and slimply moving the 3 Lascannons into your HQ Command Platoon as an Anti-Tank Support Squad. This would save you 45 points and allow them to deploy with the HQ, and not as a Heavy Support choice, which is usually first on the table top.
Additonally, i cant see your Guardsmen using their frag grenades at all unless you plan to assault with them all game. Either way, if they charge at the opponent they wont get to shoot their heavy weapons and if they stand still they wont need frag greandes. If you remove the frag greandes you have 50 extra points which when combined with the no longer needed Support Platoon Command Squad gives you 100 more points. Perhaps you can give your squads a Sharp Shooter Doctrine and reroll 1/3 of your missed hit rolls.
Also, since basiaclly all your squads have a vox-caster, a Heroic Senior Officer is definitely worth the extra 15 points as this will let you use his leadership of 9 for all the vox-caster squads rather than the Senior Officers 8.
I hope this helped :)
Discussion Starter · #12 ·
how's this guys?
HQ 114pts.
Senior officer
Standard bearer
Master-vox caster
Medic
Guardsmen flamer
Lascannon
Lascannon
Lascannon
Elites
Ogryns 135 pts.
Ogryn Bone 'ead
Ogryn X4
Ratlings X5
Strom Troopers in Chimera 189pts.
storm troop X6
Junior officer
Vox caster
guardsmen X2
Squad #1 86pts.
Sergeant
Auto cannon team
Vox caster
guardsmen flamer
Guardsmen X5
Squad #2 83pts.
sergeant
Heavy bolter team
vox caster
guardsmen X5
Squad #3 96pts.
sergeant
lascannon team
vox caster
guardsmen flamer
guardsmen X5
Junior officer
vox caster
guardsmen X2
Squad #1 86pts.
Sergeant
Auto cannon team
Vox caster
Guardsmen X5
Squad #2 83pts.
sergeant
Heavy bolter team
vox caster
guardsmen X5
Squad #3 96pts.
sergeant
lascannon team
vox caster
guardsmen flamer
guardsmen X5
Heavy Suppourt
Lemen Russ Battle Tank Hull mounted lascannon Sponson heavy bolters 165pts.
Leman Russ Demolisher hull mounted lascannon multi-melta sponsons 195pts.
1 - 12 of 12 Posts
