First off,
Close order drill only works with a squad's leadership. So you can't use your officer's Ld and then bump it up a point with COD. For a long time I thought you could that. FYI for those of you who that as I did.
Second, Iron D says squads can regroup if below 50%. However, the rule on officer leadership says squads can only use on officer's Ld if not in hand to hand, pinned, or fleeing. So does Iron D only work with the squad the officer is in, or does it work on other squads too?
While I'm asking, if you have a command squad and all 4 guard get killed, the JO becomes and IC right?
