1 - 12 of 12 Posts
i'm wondering what the best jetbike troop choice would be:
idea 1:
9 guardian jetbikes + 3 cannons
6 guardian jetbikes + 2 cannons
idea 2:
idea 3:
6 guardian jetbikes + 2 cannons + warlock (jetbike, embolden, singing spear)
or maybe take 2 squads of 3 jetbikes + cannon
these will be in an army with fire prisms, farseers (jetbike) and shining spears
comments would be nice
If you could just find those 60 points for another Warlock in last option it would be sooo great...
And think whether you want Embolden or Destructor.
404: Title not found
I'll second that, a Warlock in that last option would be pretty devastating. With jetbikes, however, you probably want numbers more than anything so you might want to consider the second option (which will be better at capturing objectives than the third). Of the three, however, if you put a Warlock in the last one (if you can, I've looked at your list and there doesn't seem to be many points you can spare) that would be my choice. If you can't I'd probably go for the second one.
DiW
Junior Member
6 with 2 cannons and a warlock with embolden and spear is the best all around jetbike unit IMO. The destructor does make the unit meaner but the possiblity of running goes up in return. I have a hard time hidding units that get much larger, bikes have a very large foot print on the table top. The only time I would go larger is if you have a cunning plan for the unit. Like a full 12 man squad + warlock with conceal and a fortune seer. They become rather hard to kill with shooting but it is a big chunk of points and can get steam rolled in melees.
Best size IMO is 6+2 cannons+Warlock. more is too much, less is not enough.
thank you for the comments
first of all, i dont have points for 3 warlocks,
so shall I...
1) take 4x 6 jetbikes + 2x shuriken cannon
2) take 2x 6 jetbikes + 2x shuriken cannon + warlock and 1 squad of 6 jetbikes + 2x cannon
3) take 2x 6 jetbikes + 2x shuriken cannon + warlock and 2 squads of 3 jetbikes + cannon
what do you think?
I know it's neither easy nor comfortable nor always possible, but use running Avathar with Fortune. It doesn't always work, but well suits me.
warlocks w/conceal
I typically only run with one squad of bikes...so take my experience in context.
I always take a warlock with a spear and Conceal. You don't turbo-boost often enough and too many people target bikes with heavy weapons to opt out of the cover save. Also, having the extra anti-tank helps a lot.
good luck! I know numbers are important, but I'd suggest running as many warlocks as you are comfortable with. I guess you could shield some units with screens of warlock upgraded squads, but with the short range of the shuricat you'd end up pretty clumped.
The problem with conceal is that youve just taken a 1 wound 63 point model. Wayyyy too much. You need to either rely on positioning to get cover saves, turboboost, or position so that you are not in range or line of sight of heavy weapons units.
Destructor warlocks dont work well consistently imo because getting close enough to use the destructor puts you in rapid fire/assault range, even with the 6 inch move in the assault. If you dont wipe out the enemy squad you can get hit hard.
Embolden warlocks are great for keeping morale/spearing a tank/taking an ap2/3 shot in a pinch. However, I think that sometimes (especially in a list thats really tight point wise) they can be excluded with no real harm done, as long as you compensate in other areas (more anti-tank options, avatar with fearless radius, etc)
Choose proper target. You're Jetbike mounted, aren't you? Or simply combine efforts of two squads with maybe a little support of tanks. I believe that the only way for Jetbikes to survive is to wipe their enemies.
Good point dire, just saying it can get a little dicey. Im used to playing space marines where there is no real "proper target" for a heavy flamer, and its hard to wipe out a tac squad in one turn. Definitely vs guard, eldar, nids, or orks you can wipe out a squad though.
1 - 12 of 12 Posts
