Question : If I want to give my Tyranid Warriors the "Leaping" power, does it need to be modelled into them? As in, do I need to cut up the legs, and use green stuff to make them look like they are leaping?
I think something like this depends alot on the attitude of the people you play with. I don't personally think that modeling special characteristics is that important, and for people that can't afford several thousand point armies, it seems quite reasonable to allow a little fudging as everybody likes to be able to mix up their lists without having to redo their models.
In the case of something like this, it should be even easier to get away with because it's the sort of thing that isn't necessarily visible.
At the last Rouge tournmet I was at I was kicked becues my guys were not leeping. The said WYSWYG is on all Nids mutations period and they pointed out its said in book 3 times that you must use WYSWTG on all morphs of nids. Hope this helps.
Another man at tournment showed me that he made movment trays, were they were leeping on the tray so he didnt half to do to much work on his 80+ bugs.
