1 - 20 of 20 Posts
I have a IG leman russ that my friend gave me that is alrdy built. Can i convert it to a heavy support choice in my Black Legion army?
Legionaire ( black legionaire)
well um.... no sorrry but only imperial guard can have it but space wolves get a variant of the leman russ
you guys that play chaos get enough stuff already
besides, what self respecting chaos player would field a tank named after one of the great loyalist primarchs of the imperium
If I remember correct (not sure though) you can use the Leman Russ tank with the new 'Lost and Damned' rules, which will come in the Eye of Terror codex later this summer.
well you may have to, to get the special rules for the tank and you need at least one squad of traitors with it to field it.
they show one with a squad of traitors and some black legion on page 21 of the new white dwarf so you have to be able to have one.
use the VDR in white dwarf it sais that if u are modifiying an already 40k tank use its points and then ad the points for the change. just whack 1 point of armour on the back (it might be a little on the beardy side thought)
what? vdr?
i dont know what that is but painting it your legions colours and converting the turrets and guns, maybe putting on some putty and giving it chaos tank gifts and a squad of traitors with chaos gifts and war gear will do and use it with what it has
Unless you play LatD (or use vdr) you can't use it, you could try to make a conversion out of it though (battle cannon would go nice with a Defiler, but the actual model is so freakin sweet).
just use it as a defiler. personalize it with spikes, gore and daemony bit and peices plus a few corpses here and there and explain to your opponent what it is before a batlle.
What the problem with using it... just convert it properly and call it something else... call it a predator... just use the approriate rules though.
I'm planning to buy a thunderer siege tank and use it as a vindicator :D
1 - 20 of 20 Posts
