1 - 13 of 13 Posts
So I have finally started to scratch build/convert some Killer Kans. I always wanted to use these, espeically in 5th ed, but never had the models. Eventually wanting to go with the full force of 9 I knew that buying them at $22 per was not an option, plus I love converting! However, walkers are not the easiest thing to scratch built and I wanted to avoid making a block on wheels. So my search for proper parts has been long, but the result was well worth the wait.
The Kan is made up of 4 main parts: Torso (with engine/backpack), Legs, DCCW and Weapon. In my opinion, the toughest two to build (and what makes a good scratch built Kan stand out) are the torso and legs. The normal Kan Model has a torso that is rounded in the front and flat on the other 3 sides (the rear has a backpack/engine on it). I had saved 35mm film canisters and pill bottles in hopes of using those for the torso, but after getting my own Kan (thanks to my god-daughter) I realized they were way to big and I also didn't want to use a basic cylinder shape. After much searching I finally found a suitable Torso, working in IT has finally paid off!
These things come with one of our printer models, they are suppose to clip onto the network cord to keep it from bending when pushed up against a wall (I think) regardless though, we don't use them so I take em. They had a cylindrical metal piece inside that I removed (to be used for something later I am sure).
I stuffed em with Green stuff and as you see, they are the perfect size!
Now my next obstacle was the legs. I had just begun to scratch build some legs out of some random parts and plasticard when my friend handed me a sack of gold! And by sack of gold I mean a bag of Mech Warrior figurines!
I immediately dove in and sawed off a couple pairs of legs and pinned them in place.
The bag o mech warriors also contained miniature tanks, of which the turrents are proven to be great back-packs/engines. I'll post more picks of those and the DCCWs as I progress. Comments and feedback are more then welcome.
NEW UPDATES
NOTE: If you cannot see my pictures it is because my website is blocked at your work. It happens to me, I cannot see my own pictures in these posts from work.
These are looking really good so far! Keep the pics coming. I've been wanting to start Orks, but have been turned away due to the metal kans, so I'm hoping this works out!
Yea, I couldn't believe it when he brought so many. He actually used some parts for his Eldar, but didn't need much else from the lot.
Ok, so started work on my 1st DCCW. I took the wreckin' ball from one of my trucks and planned to attach it to the top. If I leave it similar to this picture I will add a grot crewman to be the controller of the wreckin' ball. However, I was also thinking of trimming this down and cutting off the bottom. So the crane part would stick right out of the top/front of the kan and the chain would go down into the top or the engine I'll be putting on the back. I feel it might be too big as is... though considering the huge claw on the real Kan It might not be too bad.
Thoughts?
Discussion Starter · #11 ·
LOL, thanks for the motivation Cossack!
Did a bit more work tonight, didn't have as much time as I'd of liked thanks to dinner plans, but at least I made some progress. Added the backpack/engine on, this pieve came from one of the turrets of the tanks I previously mentioned. Cut down the DCCW Wreckin Ball a bit and added a plate and visor/eye-slit on the front. The eye-slit is the top of a wheel well from the Ork Buggy model.
Still a bit to do on this one. Need to add a glyph to the front and green stuff the edges around the engine on the back. Also need to add more to the top, including the anchor for the chain. Still deciding on where to put the weapon, right now leaning towards over/around one of the leg joints. Contemplating a "bumper" in the front and around the leg on the side with the DCCW, but no good ideas on that yet. It's coming along slowly but surely!
1 - 13 of 13 Posts
