Inquisitors and their retinues aren't the cheapest option, as they're buggers to configure their retinue correctly due to henchmen being very unflexible in how you buy them (eg. box sets, blisters) but the idea about using you're friends armies is a good one, until you can get you're own.Sycotik Pyro said:
Good, those happen to be three armies you can use with an inquisitor, lucky.Sycotik Pyro said:
Firstly, rogue is spelt r-o-g-u-e, the way you spelt it means 'red' in French, I don't really care, in fact I spell it wrong all the time, but I thought I'd just let you know.Sycotik Pyro said:
As for the radicalness, that may be a good way to go, if you're not going to include grey knights. It does mean you can have daemonhosts, which rock hard. You can still use Imperial guard and Space Marines, they just have to pretend (or actually be) kind of evil. Not literally, don't go buying Chaos Space Marines, it's just the normal space marines have to be a bit radical, fluff-wise if nothing else.
If you go pure, you can still have IG andf SM, but if you have Space Marines, you can't use Grey knights.
Basically, it boils down to this-
Inquisitor who uses grey knights can:
-Use Imperial guard
-Use Grey knights (obviously)
-Not use Daemonhosts
-Not use Space Marines
Inquisitor who doesn't use grey knights can:
-Use Imperial Guard
-Use Space marines
-Be radical
-In doing so, use daemonhost
-Not use grey knights (obviously)
You will need a HQ (in your case, an Inquisitor Lord) and two troops choices. These can either be Inquisitorial stormtroopers(can ride in tanks, can have special weapons,cheap, not so good in Close combat) or Grey Knights (awesome in close combat, have stormbolters, good armour, not so cheap). If you take grey knights, see above.Sycotik Pyro said:
Once you have HQ and 2 troops, you can induct according to the chart in the Daemonhunters codex (If you don't have that, get it or borrow your grey knight friend's).
You can also ally witch hunters, and/or alien hunters when they come out.
And remember, you can induct/ally space marines or Imperial Guard, not both. Witch hunters you can take regardless.
Hope this helped,
Nick.
