1 - 13 of 13 Posts
Does anyone have any tips for painting water well, or know of any tutorials/guides online? A bit of a search on LO and google has given me little results so far.. I'm interested in painting bases to look like they are in water, and I also have a plastic water feature on one of my models that I will need to choose colours to paint and highlight it with.
I know that for the bases you can get artificial water effect, or even use PVA glue and mix a bit of blue ink with it or something. I don't know what to do for the basecoat on the base though, put sand or paint it some kind of blue/green?
Cheers.
I suck... Maiden neck...
How to Make Wargames Terrain touches briefly on the subject, but not nearly enough to warrant a buy. Maybe you should look into the various water effects that is on the market, GW has one you can easily obtain. They are easy to use and paint right!
Hey guys, I know this is an old thread but I finally got around to painting the water effect in question.
Thoughts? I'm still not sure what to do with the bases, whether to put sand underneath. I could either put sand down and paint it up, then put that realistic water or PVA/blue ink on top, or I could skip the sand leave the base blue as it is and add the PVA/blue ink to that. And I'm not sure where to go from here with the colours of the water, I think it should be highlighted up to skull white at the very tips but that would be fairly hard to do.
Hey. Although the way you modeled the guy with the water swirling around him is freakin awesome, I can't say the water looks realistic. It looks lke some regal blue on some darker blue mix (or just a pure darker blue). I would put in more variety, as it is a large area, and work on the blending a bit more. You have very clearly defined lines between the colors.
After it looks a bit more like water (I applaud your efforts so far) I would paint it with several coats of gloss varnish.
It actually started as a mixture of enchanted blue and scaly green, the reason it goes so suddenly from dark to light is because of the blue ink I used. There is also a bit of green ink on it, but that didn't look as good. I agree the colour does need a lot more work, but thats why I'm here. :)
Father of the Failed
I really depends on what sort of effect you want to go for. If you intend the base to look like deep water then I would avoid sand altogether. For this I would work on the paint job of the base as detailed above, and when it is ready cover it in a thin layer of water effect/PVA. If you were keen on painting the very choppy bits of water as white foam, I would paint this on top of the water effect otherwise it will just look like bubbles under the surface.
If you wanted to go for a shallow water look then the fine sand approach would be the best idea.
Hope it helps,
Rich.
Discussion Starter · #12 ·
I want shallow water actually. I was thinking about doing the front rank in water (on a beach) and the second rank half water, half sand, then the back rank completely on sand.
Here are a few trials I did with water bases.
The one on the left is sand then pva/blue ink which I think looks the best (though still not great). On the top side of it I used less ink, the bottom side came out way too dark. But even the left side is fairly dark.
The middle one is painted like the wave then blue ink/pva, again the right side is darker.
And the right one is straight pva/blue ink on the black base, didn't work at all.
Thoughts?
This is going to look awesome when you finish Strewart. I can't wait to see it.
Have you tried doing sand with much less ink than in the first one.
I think that the second one looks really nice in the way that it changes depth, a blend from sandy colour at the back and going to a slight less intense blue at the front.
It is just that water is really clear till it gets deep, it would be cool if you could get a foamy effect using a snow recipe perhaps.
1 - 13 of 13 Posts
