Uhm, yes you do have to consider one thing. You can't move and shoot ALL weapons. If you move you can move and shoot either the plasma or las...not both unless the vehicle remained stationary (can pivot though)...I'm fairly certain that's right?It works just like a regular plasmagun - so rapid fire within 12", single shot within 24". The only difference is that with a vehicle you don't have to worry about if you've moved or not first.
Good point. I would think that to be correct.Uhm, yes you do have to consider one thing. You can't move and shoot ALL weapons. If you move you can move and shoot either the plasma or las...not both unless the vehicle remained stationary (can pivot though)...I'm fairly certain that's right?
Yeah that's right, cheers for pointing that out as I forgot to mention itUhm, yes you do have to consider one thing. You can't move and shoot ALL weapons. If you move you can move and shoot either the plasma or las...not both unless the vehicle remained stationary (can pivot though)...I'm fairly certain that's right?
Statistically the assault cannon kills more MEQ unless the razorback is stationary and within 12" of the target, and even then the assault cannon performs just about as well - still better if the target has cover. The assault cannon is a pretty good upgrade, if you choose to take one."Can" but not "will." You're relying on some lucky rending rolls for heavier infantry, but against lighter/medium infantry, you're in good shape.
Agreed.Statistically the assault cannon kills more MEQ unless the razorback is stationary and within 12" of the target, and even then the assault cannon performs just about as well - still better if the target has cover. The assault cannon is a pretty good upgrade, if you choose to take one.
The lascannon+plasma guns is a very odd turret, useful if you want to use your razorback as a defending tank that needs to kill 2+ or 3+ guys close-range or vehicles far away. Not very likely that it will perform best for you out of all the turrets available, but still has its uses...
Agreed.Agreed.
I personally do not like any upgrades on my Razorbacks, as IMO they're most useful to add cheap armour and a TL HB without occupying additional room on the FOC, when either is needed. The weapons upgrades are quite expensive, but they can be useful.
