Herman1004
Discussion Starter #1
Scenario:
Blood and Glory
Map:
Map number 7
Deployment:
Tinytim84 left, Tashin right
First round:
Tinytim has first round
Tashin
5x Warhounds
5x Warhounds
29x Marauders, MoK, great weapons, full command
12x Chaos Warriors, MoN, halberds, musician, standard w/ Banner of Rage
10x Marauder Horsemen, MoS, flails, light armour, standard, musician
1x Warshrine
12x Chosen of chaos, MoT, shields, musician, standard w/ Wailing banner, champion w/ favored of the Gods
Exhalted Hero, MoK, Juggernaugth, Dawnstone
Exhalted Hero, BSB, MoT, shield, Armour of Morslieb, steed of chaos
Sorcerer Lord, MoS, lvl 4, Infernal Puppet, Crown of Command, Charmed shield, Necrotic Phylactery, Diabolic Splendor
A greenskin fightingforce! Perfect!
Overall tactic
My opponent has some pretty big blocks of green guys, but thats about it. His army is very vulnerable to being scattered, so thats what I intent to do, using this three-point strategical plan:
1) Misdirecting
His two blocks of savage orcs (one being on boars) is extremely prone to my screening and misdirecting warhounds and potentially warshrine, and as he has to overrun due to frenzy, his mainforces will be out of position when it counts.
2) Fast cavalry
My opponent has two warmachines, which I plan to get rid of pretty early, by deploying my Marauder Horsemen at a favourable position to vanguard up and charge either the doom diver or rocklobber in my turn 1 or 2. After that my fast cavalry Horsemen will be able to case fleeing units, attack the rear of my opponents lines, hunt down lone characters, ect.
3) Magic
Having rolled some pretty good spells (2,3,4,6) I'll be able cause some real havoc using Hellshriek at -1 LD, or Titilating Delusions to drive his units out of position. Lastly, but most importantly, when his forces are scattered, I'll start throwing many dice after Ecstatic Seizures effectively removing 1/3 of his models in those savage units each turn.
Fighting
Having so many different possibilities of scattering the green tide, I asume that it is quite likely that I'll - if not scatter his forces completely - then pressure my opponent enough, so that I'll be able to use my vastly superior infantry units to fight his units a few at a time, and sooner or later I'll have taken enough standards for him to flee.
Deployment
I'll deploy in the top corner behind the fences and move up behind the temple of skulls, covering my chosen and warriors abit from the first few rounds of artillery fire, but I will not be in a hurry to get into melee (unless my horsemen somehow fail), since the longer I prolong the melee, the more chances I'll have to scatter my opponents forces
and thereby win.
Good luck Tinytim84. May the imaginary dice be with you.
Black ork war boss
Sword of strife
Talisman of preservation
enchanted shield
War boar
General
Savage orc great shaman
Lv3
Lucky shrunken head
Heros
Black orc big boss
BSB
Armor of fortune
Iron curse amulet
shreaking blade
Shield
Goblin shaman
Lv 2
35 Savage orc boys
(great shaman here) 6x6
Musician standard
Extra hand weapon
35 orc boyz
(BSB here) 6x6
Musician standard
Extra hand weapon
34 goblins
(goblin shaman here) 5x7
Musician standard
Shields
13 Savage orc boar boy big uns
(general here) 7x2
Musician standard
Extra hand weapon
banner of eternal flame
doom diver
Rock lobber
Well deployment will go with the goblins in the center up on the line rock lobber to the left and doom diver to the right with savage orcs next to the doom diver and norm orcs next to the rock lobba all of these are right in front of the hill. I will stick my generals unit off to the flank in between the idol and the woods hopes of getting some flank charges. First turn will be spent moving all but the war masiens up on top of the hill where they will sit and wait for him to come to me my general will move up And get in position to charge into a flank. Shooting My first target will be the genral and what ever unit he is in witch i will assume is the chosen i want to widle them down AMAP. Magic My Great shaman has Gaze of Mork, Brain bursta, Ere we go and the gobbo has vindictive gaze and night shroud. Until in combat i will be using snipeing and direct damage spells on (in order of importance) BSB and unit Large blocks of marauders. Once in combat or right before im about to be charged i will cast night shroud at the boosted level and ere we go to help me out in CC. My main hope is that i can take him down enough with shooting and magic to beat up on him in CC.
Voting ends in 72 hours.
Regards,
Hmmm...one set of tactics is a jedi mind trick designed to tell the reader what's going to happen (narrate your tactics, not your desired outcome!), rather than what the player is trying to do, and the other one seems too passive and based mostly on hope. I'd have to give this one to chaos...Orks had the opportunity to put both of his war machines on the "wrong" side of a river from the marauder horsemen, and split them instead...making the one that only has a fence for protection an easy target. He also intends to move up close and then hand the initiative over to his opponent...which seems odd. If you're not keen to dive right in and make your superior numbers count, why get any closer than you have to? Why not sit back and let the warmachines get more shots off against a numerically inferior foe? I'd think that only the great weapon marauders have the numbers to stand up to a large block of orks in melee, but if you feel that you need some damage spells and artillery to whittle them down first, that decision to move up on the hill gets him into you a turn sooner! Also, by handing over the initiative, you let him, besides letting him choose the time and place of melee combat (other than your general, the only unit you're using agressively), you're letting him draw your savage orks out with his hounds!
/edit/
Well, this is the inverse of our game, Tash, massive blocks of Orcs against smaller units of Chaos Warriors. However I believe the result will be the same, the greenskins seem to be running right into your trap (quite litteraly with frenzy) and with your magic and positioning I'd say you've turned the game round from what would have been a loss for you if there were no tactics on either side. Chaos all the way.
i am da Wahhchief
both players seem to be delaying a bit, lucky for the orcs, who spend their time getting on the hill... However, its working right into the hands of the chaos warriors: basically the greenskin lines up his troops and marches forward, ready to be split up. 1 on 1 those savages (may be outmaneuvered) will have a hard time facing warriors and chosen.
Warriors of Chaos win
PokeSavant
This sums it up perfectly. WoC.
Exciting struggle statement. Personally i think that the challenger built a big mistake together with his Farsight lower which often cost your ex the sport. They ought to have never specific the actual conscripts and also aimed at ones tanks.
___________
We provide guarantee to pass Pass4sure.co.uk - ccna answers gmat with online exam training itil and you can also get best quality newhaven.edu mcat along with kuyper.edu mcat for your guaranteed success.
