SoB Vs Crons – 1500 points
Lists:
Sisters:
Cannoness, Blessed weapon, cloak of st Asprila, frags, litanies of faith, Inferno pistol
Bodyguard: 4 Celestians +VSS W eviscerator, frags, flamer, heavy flamer
Immolator, extra armour, smoke
Sister squad: 9 sisters +Vss W plasma pistol, flamer, heavy flamer, imagifier, frags
Rhino, Extra armour, smoke
Sister Squad: 9 sisters +Vss W brazier of holy fire, flamer, heavy flamer, imagifier, frags
Serephim Sqaud: 5 serephim +VSS W eviscerator, 2x twin flamers,
Exorcist, extra armour
Retributor squad: 5 sisters +Vss W storm bolter, 4 heavy bolters
Crons: (from memory)
Lord, Staff of light, res orb, phylactery, something giving him an inv save
Lord, destroyer body, war scythe, res orb, phylactery
5 Flayed ones
14 warriors
14 warriors
3 wraiths
4 scarab bases
Monolith
2 heavy destroyers
6ft by 4ft Board is symmetrical with a hill in each corner, a line of fence running between the 2 hills in the north and the same in the south, a building, crater and wood in the middle
Deployment:
OK so he deploys first, his monolith and flayed ones are in reserve (woot woot) he takes the northern edge, he deploys right along the northern (6ft) table edge, from west to east, a warrior unit standing on the hill, the scarabs at the base of the hill, 2 heavy destroyers hiding behind the wall, as are the wraiths who have been joined by the lord with the destroyer body, the last lord has joined the last warrior squad and is on the hill in the east.
I placed my 2 exorcists behind the hill in the west, the retributors, dismounted, are stood behind the southern wall in the middle, obscured from the heavy Ds by the wood and the building, both immolators and both rhinos are in the south east, mostly out of sight behind the hill. Serephim are lurking with the vehicles.
We dice for first turn, he gets
Necrons Turn 1: All squads zoom forwards, including the heavy Ds who don’t quite get into the building. Nothing has LOS and range so no shooting, pretty ineffective frankly
WH Turn 1: the exorcists roll out 6 inches. Rest stays still.
Shooting: The first exorcist spots a heavy D and opens up – presto – he gone, the second exorcist opens up on the wraiths and lord W destroyer body, 3 hits, 3 wounds, drops a wraith. The retributors also join in (the wraiths are clearly making a B line for them) dropping the other 2 wraiths.
Necron Turn 2: Reserves: nada, WBB- 1 wraith gets back up
Movement: the warriors in the west make towards the exorcists, as do the scarabs, the heavy D makes it to the cover in the building, the wraith and lord make it to charge distance from the Retributors . The lord and his squad in the east continue on some sort of bizarre suicide pact, moving towards my vehicle/seraphim park.
Shooting: the heavy D starts by stunning the nearest exorcist. That frankly is it
Assault: brace yourselves, a single wraith and the lord charge the retributors, this kills two sisters, in a valiant display of arms, the rets fail to do anything, but decide to hang around
WH Turn 2:
Movement: the stunned exorcist pulls back behind the hill. The HQ immolator moves up to help the rets, its cargo debussing. Both rhinos and the rets immolator zoom up to the warrior/lord squad, debussing both sister squad, the seraphim also go that way.
Shooting: Exorcist takes out the second heavy D.2 full sisters squad both using Divine Guidance, plus the seraphim, plus the immolator effectively obliterate the lord and his entire squad (don’t recall what killed what, but for the record, this is: 1xtwin linked heavy flamers, 2x heavy flamers with DG, 2x flamers with DG, 2x twin linked hand flamers, 2xstorm bolters, 3x twin linked bolt pistols and 16 rapid fired bolters with DG).
Asasult: the Celestians and the Canoness pile into the wraith and the lord, using the passion, the Canoness puts 2 wounds on the lord, the combined might of the celestians and the rets pull down the wraith and the lord losing a single celestian.
Necrons Turn 3: Reservers: the monolith arrives right next to the vehicle/troops on top of the hill
o) the flayed ones, clearly worried, deep strike next to the warrior squad in the west.
WBB: the lord in the east fails to get his phylactery to work so they gone, the lord with a destroyer body comes back on one wound.
Movement: The remaining warrior squad heads towards the visible exorcist and adjacent retributors. As do the scarabs and flayed ones. The lord W destroyer body charges the celestians
Shooting: the monolith defensive guns killed one sister. The template landed neatly on the seraphim squad, wiping it out (oh well, more faith points back)
The last warrior squad tries it luck against the retributors and drops one
Assault: the lord W destroyer body finds himself killed although manages to put a wound on the canoness
WH Turn 3:
Movement: Both sisters squads jump into their rhinos and zoom away from the monolith southwards. The immolator follows suit. The exorcist behind cover moves out, the Celestians and Canoness leap back into their immolator and roll back behind the exorcists.
Shooting: The exorcists open up on the warriors, killing 4 ought right – no WBB for you my son. The remaining retributors open up killing a couple more warriors, now roughly 4 models away from phase out,
Necron Turn 4.
Movement, the monolith drifts south west towards the action, the scarabs and flayed ones move to change the luckless retributor squad, the warriors move to rapid fire one of the exorcists.
Shooting: the monolith defensive guns get an armourment destroyed on one of the rhinos, its main gun deviates and fails to take out the rhino it was aimed at
The warriors manage to stun an exorcist.
Between the flayed ones and scarabs, the rets are destroyed.
WH Turn 4:
Movement: the 2 rhinos and empty immolator move up to the flayed ones and scarabs and debus their squads. The HQ immolator moves alongside the warrior squad and everyone gets out.
Shooting: the exorcist takes out a couple of warriors, the HQ squad with divine guidance and its immolator drops the warrior squad down to its last man who promptly fails his moral check and runs about 9 inches.
The 2 sisters squads, again using devine guidance and supported by immolator and rhino fire, wipe the flayed ones from the face of the planet.
Currently on the board is 1 warrior, 4 scarab bases and a monolith. With nothing eligible for WBB – he phases,
Absolute spanking victory
Lessons/points:
His deployment was shockingly bad, just not thought through at all, pretty much cost him the game.
Wooot that drive up, get out and use divine guidance was spectacular on every occasion
Lists:
Sisters:
5 Flayed ones
14 warriors
14 warriors
3 wraiths
4 scarab bases
Monolith
2 heavy destroyers
Deployment:
WH Turn 2:
WH Turn 3:
Necron Turn 4.
WH Turn 4:
Lessons/points:
