I know this is a completely stupid question to ask but in what rulebook does it tell you what templates the frag, toxin and bio-acid spore mines use? I've been flicking through the codex for a while now and i can't seem to find it.
Yes. When a description says "blast" or when it says to use the "blast marker" or "blast template", always assume that they're talking about the small blast template. If it wants to to use the large template, it'll specifically says so.
Actually it's smaller than that. It's 7.5 cm in diameter, which is a tiny bit less than 2 31/32". As such, centering it on a model means that even if adjacent models are in base contact, you only get one full and two partials. The large blast marker is 12.5 cm in diameter, which is almost 4 15/16".
