Tanith 1st (and only) 1000pts
Senior Officer (Rawne)
(55) Trademark Item (10) Tanith (45) Frag (5) Krak (10)
Total = 125pts
Fire Support Squad
(35) 3x Auto cannon (60) Tanith (45)
Anti Tank Support Squad
(35) 3x Missile Launchers (60) Tanith (45)
Total = 280pts
Elites
Commissar Hark
(40) Independent (10) Plasma Pistol (5) Bionics (5)
Total = 65pts
12th Platoon (Domor)
(60) Tanith (45) Flamer (6) Sniper (5)
Junior Officer Domor (40) Bionics (5)
Total = 277pts
Armoured Fist Platoon (Bluebloods)
(60) Grenade Launcher (8) Veteran Sgt Culcis (6) Bionics (5) Carapace (5) Bionics (5) Bolter (1)
Total = 85pts
Blueblood Chimera
(70) 2 x Heavy bolters (15)
Total = 85pts
What do you think?
Venerable Old One
Ah, Angel. How are the folks at Imperial Literature?
1 ) Fire Support. Autocannon really arent worth the points. They fall into a narrow bracket of a weapon trying to be both an infantry killer and a tank hunter. The result is not a pretty weapon to use. Suggestion: Drop the autocannon for heavy bolters, and upgrade the missile launcher squad to a lascannon battery.
2) Platoons. Flamers? Are they really worth it? Every squad should take at least a Plasma or Melta gun for anti tank and anti elite stuff. Only use the flamers if going against Orks or Nids.
3) The chimera: Can it actually have two heavy bolters? It has one in the hull, a multilaser in the turret, and a pintle-mounted stormbolter on the turret rim.. unless you're using a forgeworld mod in which case that gives it three heavy bolters.
Nicely rounded, if lack of serious anti tank weaponry.
They are.......as normal as they can be...
1) I'm giving them a trail run at the moment, if they don't serve I'll swich them for Heavy bolters as you suggest....as for the missile Launchers I have them in there as they have always served a double role in all my armies..both anti infantry and anti tank. (I adore krak rounds)
2) I see your point, perhaps I will swich them for a plasma gun instead
3) They can take two Heavy bolters, one as an option in the turret and one on the hull
a/ give the chimera its multilaser back, this is almost my favourite composition as once the chimera has served its perpose (pimp wagon), it is also an adequate tank in itself.
b/ since this is a tanith army, relying on stealth, the armoured fist squad aint very appropriate, nothin louder than a chimera (apart from and ork bike)
