1 - 15 of 15 Posts
Hive Tyrant
Bone sword and lash whip
Heavy venom cannon
Old adversary
Acid blood
Paroxysm
Leech essence*
Tyrant guard *3
Tervigon
Scything talons
Acid blood
Elites
Zoanthropes *3
Mycetic spore
Hive guard *3
Doom of malantai'*
Mycetic spore
Fast attack
Gargoyles *18
Adrenal glands
Warriors *5
Scything talons
Rending claws
Toxin sacs
Termagants *18
Devourers*
Genestealers *11
Toxin sacs
Hormagaunts *15
Toxin sacs
Trygon Prime*
Toxin sacs
Carnifex brood *3
Crushing claws*
Scything talons
Toxin sacs
Tyrannofex
Rupture cannon
Total 2993
The first thing that jumps out at me is the Carnifex brood. A trio increases survivability but Crushing Claws are just crushing defeat. No matter what you do they go last in close combat. That means you'll be taking wounds on the way in to combat and have to take a round of wounds before you take a swing. I'd scale back, maybe go with scything talons and twin-linked devourers with brainleech worms. Or forgo the 'fexes all together, get a second Tyranid prime, and pump the remaining points into a second Tervigon or Harpy, assuming you want to stick with monstrous creatures.
Hello thanks for your advice how do I make a twin linked Devourer for the fexes?
Anything else you would recommend?
Thanks
The Carnifex kits come with right and left arm Devourers. Sounds like you don't have them. You can often find them on eBay for a few bucks a set. They don't require any customizing. As for any other suggestions it would help to know who you will be up against.
In my experience a great unit for taking out orks is Biovores. Rain spore pods down on the green wave as it advances to thin it down as much as possible. Consider swapping out the Carnifex for a brood of three. MCs can do some damage to be sure, but if you get into CC the weight of Ork attacks is just going to swallow them up. So Rupture Cannon is good if your opponent is bringing Kans or Dreds, and definitely against IG armor spam, but if you know your opponent likes to bring the green wave consider switching to the acid spray. A nice template that you can put 12 inches out in front of the unit and then aim!
For your Tyrant, which looks like you want to be close combat orient, you may want to swap out twin-linked devourers with Brain-leech worms. 6 shots with re-rolls to hit is pretty decent, and the guns can crack transports and trucks.
Tervigon really aren't meant to be close combat units. They can fill the role of course, but there are better options. Consider dropping the talons and acid blood in favor of buffs that benefit other more offensively minded units. Catalyst to give assaulting units FNP. Toxin and Adrenal to buff your Termagant spawn. Makes them particularly effective against IG. You can keep the other buffs of course, if you expect your opponent to go after her, but in my experience the points are better spent elsewhere.
I've never played at the 3000 point level, but I imagine that any points you save by dumping the Carnifex should go towards your troop slots of which you've only filled four. Maybe you can afford a second Tervigon and 10 Termies. At lower point levels if your single Termagant craps out in spawning you've still got a chance. I imagine at this level if you're relying on one Tervigon to spawn scoring units you'll probably be disappointed. And I would suggest not spawning until you have to regardless. Few things more frustrating than spawning four Termagants in the first turn, crapping out your Termagant for the rest of the battle, and then having the opponent gun down the 'gants for an easy kill point.
Ok confused at how many troops I can take and why I thought I could only take 4 ?? And cool the bio vore does sound quite cool!! The tervigon will be used defensively after your suggestion I guess it will be safer
Regarding the Tervigon, there's a middle ground between offense and defense where this unit shines. Don't be afraid to advance with the unit. keep it and its surrounding Termagant broods moving forward. Press the enemy. Make your opponent choose its poison. With six wounds and high toughness you create a target priority issue. Do I shoot the Tyranid prime advancing on my left flank? The Hive Tyrant rushing up the middle? The Tervigon and its wave of shooty gribbles coming up on the right? Oh crap, where did those Warriors come from?
If you hang back and play defense, do it to protect a home objective. But don't play defense just to avoid combat. In a tournament I once spawned three broods of 12 plus from one Tervigon. Sounds great, but I ran out of turns before I could use them to win the battle. Sure, my opponent had no chance of taking my home objective, but I was nowhere near close to taking his and with all those numbers I could have rolled him. Too cautious. Plus, if you don't advance you aren't taking advantage of the toxin sac and adrenal gland benefits you give surrounding Termagant broods (once they're outside six inches of the Tervigon the benfits are lost). The Tervy can absorb a bit of shooting damage before going down. If your opponent guns her down in one turn then they should pay for it with other units getting within charge range.
Discussion Starter · #10 ·
So you think the list is okk?
Is the Trygon better deep striking? I need a bit of advice on how to use a Trygon properly if possible?
Regarding the list, I think its solid. But one man's cake is another man's tofu, right? So much depends on what your opponent fields, but mostly it depends on what you like and the kind of army you enjoy running. The only additional consideration I can think of would be regarding your Warriors. The brood is the right size, and you've clearly kitted them out for close combat. Against Orks they should do well with claws and scytals. And against IG they're kitted out to pop transports. Your challenge is going to be how you deliver them into combat. I assume your plan is to run them. If so take advantage of a screening unit and cover. IG has a lot of weaponry that can make small order of a toughness 4 creature. S8 AP3/2 is a Guard's worst nightmare.
Regarding the Trygon again, it depends on your enemy. Against orks I'd keep it on the table because you'll want to control when and where he hits the enemy. That and Orks have such crappy Ballistic skills you shouldn't have to worry about losing him to missile fire, especially with all the other prime targets. Against IG its sixes. Keep him on the board to mess with their target priority and run him like hell. If your opponent keeps armor in his backfield just sitting there, maybe deepstrike and make him pay for it. 12 S5 Containment Spine shots have a good chance of stunning on side/rear armor facings. They can also make life miserable for any infantry units lagging at the back popping off rocket and artillery shots.
Edit: S8 AP3/2 is a "Warrior's" worst nightmare.
If by TLDS you mean twin-linked Deathspitters or Devourers, Warriors can't have them. Choice of missile weapons is unique to everyone. I try to keep Warrior costs under control. If I upgrade the gun, I stick with basic CC weapon. If I upgrade to Boneswords I keep the Devourer. Range being equal, Devourers are good against IG with the -1 penalty to leadership. Deathspitters are good against Orks with the AP5 eliminating armor saves. Put a basic Tyranid Prime with them and you make any missile/melee combination potent, plus you can soak up a couple hits that would normally ID a regular warrior.
No problem. And an important correction on Force Organization and troop choices. Two Troop choices are compulsary in a standard match. Up to four optional Troop choices can be selected for a grand total of six Troop broods. Don't know where my head has been today!
1 - 15 of 15 Posts
