Objectives:
Kill Points.
Mission:
Start on the table with 1 troops choice. Everything else is held in reserve.
Set up:
Dawn of War
List 2
Kill Points.
Mission:
Set up:
Dawn of War
List 1
Fireblade 60
+fire warriors (10) 150
commander
TL fusion blaster
Missile pod
Puretide
Shield generator 160
Crisis suits (3)
TL Fusion blasters
Missile pod (3)
Counter fire (3) 186
Piranhas (4)
Fusion blasters (4) 200
Hammerhead
Longstrike
Smart missiles
Disruption pod 185
Riptide
FNP 215
Broadsides (3)
H. Yield (2)
Target lock (rife) 200
Broadsides (3) as above 200
Pathfinders (10) 110
Stealth team (6)
fusion blaster (2) 190
List 2
Pask's 909th Assault Group (Astra Militarum CAD with Elysian Detachment D-99 Allies) [2000pts]
Pask's Leman Russ Squadron (Tank Commander Pask, Warlord, Leman Russ Vanquisher) with 2 Leman Russ Vanquishers, all three have Hull Mounted Lascannons [505pts]
Armour Defense Platoon (Infantry Platoon) [210 pts]
- 3 Infantry Squads with Krak Grenades
- Platoon Command Squad
Objective Defense Platoon (Infantry Platoon) [150 pts]
- 2 Infantry Squads with Krak Grenades
Air Support Triad [465 pts]
- 3 Vultures with Twin Linked Punisher Gatling Cannons
Precision Bombardment Batteries [390 pts]
- 3 squads of 2 Wyverns each
Deep Operations Command Squad [120pts]
- D-99 Command Squad, Captain with Tracking Beacon, 4 meltagun Veterans
Deep Operations Support Squad Alpha [80 pts]
- D-99 Veteran Squad, Sergeant with 2 plasma pistols, 1 meltagun veteran, 3 lasgun veterans
Deep Operations Support Squad Bravo [80 pts]
Total Loadout:
Vehicles (12 models):
3 Leman Russ Vanquishers with hull Lascannons
3 Vultures with Gatling Punisher Cannons
3 x 2 Wyverns
Infantry (75 models):
5 Infantry Squads with Krak Grenades
2 Platoon Command Squads
D-99 Command Squad with 4 meltaguns and a homing beacon
2 D-99 Veteran squads with 2 plasma pistols and a meltagun, each
Tactics:
Tactics depend on the terrain and the opponent. In most casts, wyverns will deploy in the most protected way possible, not needing line of sight to Shred things. Pask's Vanquisher Squadron will deploy for best LoS options possible. Majority of Infantry will deploy to protect the armour from alpha-strikes and the like, hopefully using conga line techniques to prevent drop pod spam if necessary. They can also deploy as two big squads instead of 5 if kill points is a thing. Any extras will camp objectives. D-99s will project a deep threat, and will drop down wherever they can have the most use. D-99s can also deploy normally if Deep Striking is not advantageous. Vultures are highly mobile and will hit priority targets as soon as they get on the board.
All in all, this list will shred anything that isn't heavily mechanized. Pask's Warlord trait gives Preferred Enemy(pick a factor) to the entire CAD. Wyverns will vape anything less than T8 very quickly, especially when there are high model counts. Vultures will likewise cause a lot of wounds to anything less than T10, can maul flyers, and can glance AV11. The vanquishers will concentrate on anything armoured first, and 2+ saves second. D-99's will aim to do as much backfield damage as possible, or if it's more advantageous, grab objectives. Platoon command squads will hide and send orders at the Infantry Squads, and become objective grabbers/bubble wrap as necessary. Finally, any vehicle that comes close to the Infantry Squads can expect to get swarmed with krak grenades.
