Complete newbie that needs a good standard tournament list to practice with before main event ;)
LORDS
Bloodthirster
Armour of Khorne
Axe of Khorne
Firestorm Blade
Spellbreaker
HEROES
Herald of Tzeentch
Daemonic Robes
Disc of Tzeentch
Winged Horror
Skull taker
Juggernought of Khorne
CORE
Bloodletters x30
Standard Bearer
Blood reaper
Horrors x15
S Bearer
The changeling
Horrors x20
S Bearer
Special
Flesh hounds of Khorne x6
Rare
Bloodcrushers x3
S Bearer
Bloodcrushers x3
S Bearer
2478
What do we think please tear it apart
My advice is in red.
LORDS
Bloodthirster
Armour of Khorne
Axe of Khorne
Firestorm Blade
Spellbreaker
Drop the Axe for immortal fury.
HEROES
Herald of Tzeentch
Daemonic Robes
Disc of Tzeentch
Winged Horror
Drop the disc and; 1 drop wings for master sorcery life and sit in the block of horrors, 2 drop robes for master sorcery death and use him to debuff and kill champions/characters so your BT doesn't get challenge blocked.
Skull taker
Drop the jugger, + Add a Herald of Khorne with Daemonic robes and Armor of Khorne.
CORE
Bloodletters x30
Standard Bearer
Blood reaper
Drop the reaper, add musician.
Horrors x15
S Bearer
The changeling
Drop down to 10 and then merge with other horror block. Use the extra points for more letters in your horde and a musician for the horror block.
Horrors x20
S Bearer
use extra points to take the +1 casting banner for them.
Special
Drop to pay for the herald of khorne and extra horrors/letters in your blocks. Plus make either herald a bsb you dont need a magic manner if you dont want but at least take the bsb. If you use the death HoT go with the HoK as the bsb.
Rare
you could try making them one unit of six, 3 wide/2 deep and change the extra banner to a musician then.
Bloodcrushers x3
S Bearer
Bloodcrushers x3
S Bearer
Wow thanks great stuff
Hows this
Blood thirsted
AOK
Firestorm blade
Immortal Fury
Spell break
Herald of Khorne
AOK
Daemonic Robes
Battle Bearer
Banner of Hellfire
Herald of Tzeentch
MOS Life
Herald of Tzeentch
MOS Death
Bloodletters x40
Musician
SB
Horrors x31
The Changling
Musician
Icon of Sorcery
Bloodcrushers x6
Musician
SB
That is better, but if you are not gonna have the skulltaker in with the HoK then you may want the reaper back in the unit. (they can/will take challenges for your bsb)
Lore of death is good but you really need the mobility of flying to make it work. Also since you are newer I would stick to the easier style of the life HoT. You have to many things wanting power dice right now, best to just have 1-2 casters. (currently you got the 2 heralds, the pink horrors and the banner) I would drop the hellfire banner, it is not as good as it looks in 8th. Despair or Sundering are the good magic banners but you dont need to have one on the bsb he can just have a normal banner which is comes with his bsb cost.
I only suggested combining the units of crushers together cause I prefer them that way, nothing was wrong with how you had them if you wanted them that way.
Also a hint for ease of movement tray use is don't have a perfect block worth of units, if you gonna add characters to the block, instead short it the few needed. Example if you plan to put the skulltaker and a HoK in a bloodletter block do 38 bloodletters not 40 that way after they join it is a nice full movement tray not a movement tray plus 2 dudes tagging along behind it.
I know it been a while but here is an update
Lord
Bloodthirster
AOK
Firestorm Blade
Immortal Fury
Spellbreaker
Heroes
HOK
AOK
BSB
Daemonic Robes
HOT
Disc
Master of sorcery : life
Skull taker
Core
Bloodletters x38
Sb
Horrors x39
Changling
SB : icon of Sorcery
RARE
Bloodcrushers x3
SB
Bloodcrushers x3
SB
2498
hello my other daemon player right so with your list there are some good points about it i like the bloodletters but maybe drop them to 30 not 38. Now some people like the big units of horrors but i am not that keen on them if you drop them to ten and try and fit another unit of bloodletters 30 again and put your hoz on light take him of the disc and put him in that unit. try and get 2 hok in there somewhere so they an go in the bloodletters unit and give hatred with the hoz doing light spells on them to make them even harder and i also don't like taking grater daemons because if they die you have lost a huge amount of points and lost your hard hitting lord so my advice would be add more heralds.
