1 - 18 of 18 Posts
Lord of the Household
<_< Because it would be bad fluff... Also, the Emperor is a rotting corpse.. Only his Divine Mind is still alive. The High Lords of Terra could use his DNA to create new 'Primarchs' if they wished but they would not dare attempt such an epic undertaking, nor would they want to. We all saw what happened with half the Primarchs the last time they tried..
less then half of the primarchs turned to Chaos so only making 2 or 3 would minimize the risk.
But i can see why the high lords would not do it. They are supposed to interpret the emperors will but they would probably have to turn over power to the emperors "sons".
Which also would be immensely dangerous... Who knows what they might do... :unsure:
Professional Lurker
of course they could subject the primarchs to a soulbinding when they were young theyre so strong theyll probably still be able to see and they would be stronger and unable to turn traitor
ok then fine but why dont they just make the emperor a new body or transfer his mind into a really hard guys body. then the emperor could get off his arse and kill abbadon, then display his head on a large stick. :D
Perhaps they can't clone at all any more. It says that lots of technology was lost and anything that they do know is more ritual than real science. And other people were right, the half of the primarchs that screwed up are causing them enough trouble!
dude, if they can put a space marine's mind into a dreadnought, then put the emperor's into a warrior body, whether it be mechanical or flesh.
an emperor dreadnought??? :huh:
Lets see, the armour value of a land raider
the ard to kill ability of a venerable dreadnought
the living metal ability of a monolith
and a bunch of lascannons and plasma cannons
I think the imperium would be slaughtering everyone by now
maybe not as bog, make it like an arnold type terminator or something, then when technology becomes more advanced, whenever that will be, put him in an actual body.
just take his mind and soul and make him like an 1000 son, animate hin mind and soul into a piece of armor, termi or possible power
If you've got a fluff book called "Index Astartes II", it details the Cursed Founding where a bunch of scientists tried to create Super Marines, and failed dismally (thanks to Chaos). If the creation of these mere Marines could be detected and stopped, then chances are that the Imperium has no hope of creating more Primarchs.
'Owned' might be a bit of a misleading term... They are the base of the geneseed of all Space Marines and each is the first in line of the First Founding Chapters.
You may have heard some of their names? Roboute Guilliman (Ultramarines), Sanguinius (Blood Angels), Leman Russ (Space Wolves), Lion El'Johnson (Dark Angels), Rogal Dorn (Imperial Fists)...
They were twenty in all including Horus whom you MUST have heard of...
You know Russ got the Emps strength, Saginuis his bravery, Dorn his commitment, Horus most things, What did El Johnson get?
1 - 18 of 18 Posts
