I have started some work on the new plastic Battlewagon - and finally gotten around to putting one of my trukks together. Here's the scheme so far:
Battlewagon 1 - front cabin, front chassis (four wheels) and part of rear cabin built. Awaiting purchase of other battlewagons, so I can supply this one with four or six more of the same style of wheel. This will be a Stryker or ASLAV style Battlewagon.
Battlewagon 2 and Trukk 1 - cut and shunt to make the Flakka Trakk. Left over bits going into sundry vehicle projects.
Trukk 2 - being built pretty much standard, with a touch of kustomization to distinguish it from other trukks.
Here's the Flakka Trakk so far:
It comprises the track units and rear bed of the battlewagon, joined to the cabin and front wheels of the trukk. Wheel arches and front pieces come from the old plastic war buggy set.
The 'chassis rails' that join the two structures are from the straights and L-pieces in the modular movement tray set. Fuel tank is from the Imperial Guard vehicle accessory sprue. (The wheels and tracks aren't glued on; I will paint the body before attaching them.)
The trukk has been built pretty much out of the box, but with a lot of the spiky bits clipped off. The truck-bed sides from another trukk kit have been cut down to close in the truck bed a bit more. The gaps in the piece behind the cabin have been covered with Forgeworld ork glyphs and pieces of strip styrene.
PLMKWYT
Cheers,
TOMB
(My Blog)
PLMKWYT
Cheers,
TOMB
(My Blog)
